NEED HELP! H22 swap (what is this solenoid, where does it go?)!!!!!!!!!!!!!!!
I just did my JDM H22 swap and have a question about the vacuum solenoid that is in-between the fuel pressure regulator and the manifold…do you know which pin it is connected to on the ECU or what I should wire it into. Im guessing it has something to do with the secondaries but am not sure. Thanks!
EuRoBrO
Jul 20, 2004 11:52 AM
