BEST SETUP TO USE WITH T70 GSR TURBO, FULLY BUILT?????
Old Jul 20, 2004 | 08:03 AM
raceteamintegra86's Avatar
Default BEST SETUP TO USE WITH T70 GSR TURBO, FULLY BUILT?????
i have a gsr, T70 setup, with a fully built bottom and top end. i just got a 8lb findanza flywheel to match a good clutch. wat clutch you guys think i should get.
i have no hp configurations yet because we didnt run it yet. i will be boosting around 15psi during races and only 5 or so on the street. i need a clutch that can hold that power but be comfortable to drive every day to work and onther ****.
Old Jul 20, 2004 | 08:11 AM
jDMJeRk's Avatar
Default Re: BEST SETUP TO USE WITH T70 GSR TURBO, FULLY BUILT????? (raceteamintegra86)
Ive also been looking into a clutch and this is what I kinda feel:
-ACT: grabs really hard, pedal is not even near to stock feel, very pricey
-Exedy: cheap, grabs hard, little bit better pedal feel vs act; act grabs harder; but I liked the exedy more
Ive used both act and exedy btw
Im thinking about using a action clutch this time. It seems to be a good clutch from what Ive read.
hth a bit
Old Jul 20, 2004 | 08:12 AM
PM-Performance's Avatar
i think you are a little mixed up my Friend. No "Stage 3 kit" nor any kit will come with a T70. Also there is no way you would even spool a T70 . let alont run 5psi on the streets and 15psi at the track . more like 15 on the streets and 30 at the tracks is more like it.
without TQ figures there is no way to guestimate a clutch for your set up . how bout you post some pics of this supposed set up
Old Jul 20, 2004 | 08:28 AM
spark plugs.
Guest
Posts: n/a
Default Re: BEST SETUP TO USE WITH T70 GSR TURBO, FULLY BUILT????? (itr206)
that's wtf i'm wondering! T70 turbo on a honda?! i've heard people in NY crap-talk about t66 turbos in their stock motor civics.
supposing that your honda COULD take the T70, there's no clutch currently on the market that'd be able to take that torque and still be streetable.
Old Jul 7, 2005 | 06:14 PM
for your fact i am running a t70 turbo!
81.5 mm bored B18c1
Eagle Rods shot pinned arp bolts
Arias 8:5:1 dished turbo pistons, turbo rings
type r crank balanced and knifedged
eagle block gaurd
all new bearings in the whole motor. new oem water, oil pump, timing belt, thermo
B18c1 head
ported polish
3 angle job
all titanium valves springs and retainers
aem cam gears
arp head studs
t70 turbo
hks mani
custom 3" dp
custom 3" exhaust
tial 38mm wastegate
turbo xs rfl bov
phatom grip lsd
stage 5 axles (500hp)
ACT Stage 4 4 puck sprung hub, w/ heavy duty pressure plate
findanza 8lb flywheel
rc 1000 cc injectors
walbro 255 lph fuel pump
ac turbo fuel rail w/ gauge
aeromotive fpr
msd dizzy cap
blaster coil pack
boush racing ignition rotor
msd 6a
skunk2 coilover syspension, kyb struts
comptech strut bars
tuned by neptune!!!!!!!!!
Old Jul 7, 2005 | 06:29 PM
weak_tec's Avatar
if i can recall, there was an issue i believe it was honda tuning not sure, they had an article about a fully built b18c running a gt72 turbo at about 25 psi that made over 600hp...it is possible
Old Jul 7, 2005 | 07:15 PM
hawjboi's Avatar
with all that power Why a Phantom Grip LSD...
Old Jul 8, 2005 | 02:17 AM
Danger's Avatar
lol , almost a year later you decide to respond ?
happen to have a pic of your set-up ? list you have up there is pretty nice
Old Jul 8, 2005 | 09:26 AM
adseguy's Avatar
Default Re: BEST SETUP TO USE WITH T70 GSR TURBO, FULLY BUILT????? (JonDanger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonDanger &raquo;</TD></TR><TR><TD CLASS="quote">lol , almost a year later you decide to respond ?
happen to have a pic of your set-up ? list you have up there is pretty nice </TD></TR></TABLE>
hahahahahaha....good eye. I'd like to see as well
Old Jul 8, 2005 | 09:33 AM
b18vtek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spark plugs. &raquo;</TD></TR><TR><TD CLASS="quote">that's wtf i'm wondering! T70 turbo on a honda?! i've heard people in NY crap-talk about t66 turbos in their stock motor civics.
supposing that your honda COULD take the T70, there's no clutch currently on the market that'd be able to take that torque and still be streetable.</TD></TR></TABLE>
T66 on a stock motor............i don't know about that, But my friend has a T70 on a built LS/V, making 450whp on 15psi. Tuned By DRT
If you hang around DRT you will see nothing but honda's with BiG *** TuRbSs!
DA_PoWeR
Transmission & Drivetrain
Apr 4, 2010 08:54 AM
UpstateCivic
Apr 15, 2004 08:19 AM
TuRbEeZy
May 14, 2003 03:17 PM
VR6T
Apr 27, 2003 09:15 AM
Fez
Mar 11, 2003 10:16 AM
