what timming belt for b16a sir?
Old Jul 20, 2004 | 06:14 AM
sullenht's Avatar
Default what manual to get for sir b16a?
what timming belt water pump and oil pump for b16a sir. part numbers would be great. and avrage cost thanks in advance. Carlos
Modified by sullenht at 4:48 PM 7/20/2004
Old Jul 20, 2004 | 06:24 AM
WAFFLES's Avatar
Default Re: what timming belt for b16a sir? (sullenht)
I don't have the part numbers off hand but
T-belt, about $45
water pump, $95
Oil pump, $105
Order all of them for the 99-00 Si
I always recommend installing a new tensioner spring and pulley when doing a t-belt and pump.
Old Jul 20, 2004 | 06:40 AM
sullenht's Avatar
Default Re: what timming belt for b16a sir? (WAFFLES)
thanks so a 99 si will work also what would be a good shop manual to get and where would i get my hands on one
Old Jul 20, 2004 | 06:57 AM
WAFFLES's Avatar
Preferably a Helms, that is the best manual. But if you can't get one(they are pricey) get a Chiltons manual. The helms is going to cost around $70 and has more info in it than the other manuals. The Chiltons is about $25 and can be found at most autoparts stores.
Old Jul 20, 2004 | 07:03 AM
sullenht's Avatar
would that be for the 99 00 si ?
Old Jul 20, 2004 | 07:54 AM
1fastVX's Avatar
I have a JDM B16a Sir2 motor in my 92 Civic hatch and I have always used parts from a 95 Del-Sol VTEC. I try and stick with the same generation as the motor...my motor is from a '93 Civic in Japan.
PS...I also purchased the Helms manual for a 95 Del-Sol
John
Old Jul 21, 2004 | 04:05 AM
93H22ACX's Avatar
Default Re: what timming belt for b16a sir? (1fastVX)
go to hondaautomotiveparts.com for part numbers and prices. Del Sol VTEC and Civic SI have different part numbers so i assume they're different...
EDIT: Didnt read the part about it being and SIR so maybe a Civic SI will
work
Old Jul 21, 2004 | 05:59 AM
WAFFLES's Avatar
Default Re: what timming belt for b16a sir? (93H22ACX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93H22ACX &raquo;</TD></TR><TR><TD CLASS="quote">go to hondaautomotiveparts.com for part numbers and prices. Del Sol VTEC and Civic SI have different part numbers so i assume they're different...
work</TD></TR></TABLE>
Different part numbers, same part. I don't know why they changed it. It still has the same number of teeth.
Old Jul 21, 2004 | 06:00 AM
93H22ACX's Avatar
good to know that
Anthony Marino
Oct 27, 2016 12:21 AM
JasonYo
Feb 22, 2010 06:55 AM
cadeMFjohnson
Nov 23, 2009 09:56 AM
TYPErCRX
Feb 13, 2006 10:40 AM
KL14
Oct 28, 2005 09:36 AM
