Honda S2000 Honda S2000
springs for s2000, found some HKS ones? any good?
Old Jul 20, 2004 | 12:31 AM
djnikko's Avatar
Default springs for s2000, found some HKS ones? any good?
ive seen some second hand HKS springs for a s2000, just wondering if there any good? will they dramaticly shorten the life of my stock shocks?
Thanks
Old Jul 20, 2004 | 07:57 AM
evil vapor's Avatar
Default Re: springs for s2000, found some HKS ones? any good? (djnikko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko &raquo;</TD></TR><TR><TD CLASS="quote">ive seen some second hand HKS springs for a s2000, just wondering if there any good? will they dramaticly shorten the life of my stock shocks?
Thanks</TD></TR></TABLE>
the valving will deteriorate over time as you've reduced the travel on the shocks with the shorter springs, that's the case with all lowering springs. From the factory, the shocks could use more rebound dampening, and it'll only get worse with lowering springs. If you're tight on funds, you can either wait and save up for new chocks (koni yellows) or just get the springs now and then pay someone again for install when you get the shocks.
Old Jul 20, 2004 | 11:16 AM
PNB's Avatar
PNB
GatorNATION
Default Re: springs for s2000, found some HKS ones? any good? (vapor)
Do the install yourself. Its EXTREMELY easy. Find the DIY on S2ki.com and follow it. Took me about 2 hours with friends, (don't do it alone).
Old Jul 20, 2004 | 07:26 PM
papa5murf's Avatar
Default Re: springs for s2000, found some HKS ones? any good? (PNB)
if you track your car hks springs are bad.. it's not much of a drop i think 1 inch..... but they are great for street......if you were just to get springs you should go with esphiler (i spelt it wrong) but my buddy has those on his s and it's got about a 1.33 to 1.5 inch drop and it still ride very very nicely with no aftermarket shocks....
Old Jul 21, 2004 | 09:25 PM
neo1z's Avatar
Default Re: springs for s2000, found some HKS ones? any good? (03s2kblue)
Yea - grab a friend and do it. Its a great DIY job - youll learn alot about your suspension as well.
Dont rip the ball joint boot. I say this simply because I just did that last night. Spilled grease everywhere...erg.
Old Jul 22, 2004 | 12:14 AM
dave22's Avatar
The drop depends on the springs. If you've found an original set of Super Forms (black) then the drop is pretty good. Something like 1.5 or more. If they're the newer SF5s (white, I think) the car will sit a bit higher.
Neither will be ideal for track use. The rates are pretty soft compared to most coilover setups.
I've got the original Super Forms on my car. I'll post pics if you want to see what the drop is like. Just let me know
Old Jul 25, 2004 | 08:27 PM
evil vapor's Avatar
Default Re: springs for s2000, found some HKS ones? any good? (neo1z)
ball joints don't need to be touched when swapping out shock/spring assemblies.
Old Jul 27, 2004 | 09:19 PM
neo1z's Avatar
Actually - the Helms says to take a ball joint separator and take it apart to do it.
I was pissed - because then I realized that I didnt need to. Managed to rip a boot though. Standard.
Old Jul 27, 2004 | 11:45 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo1z &raquo;</TD></TR><TR><TD CLASS="quote">Actually - the Helms says to take a ball joint separator and take it apart to do it.
I was pissed - because then I realized that I didnt need to. Managed to rip a boot though. Standard.</TD></TR></TABLE>
lol, the helms says a lot of stuff, but you don't have to follow the helms. Some time around ball joint seperation will show you what a big hammer can do in popping out a ball joint. It's quick, easy, and painless (unless you smack something other than your ball joint).
Old Jul 28, 2004 | 08:29 AM
wickeds2k's Avatar
Default Getting ahold of you...
Hi Vapor,
I recently bought Raymond Youngs car. You have a set of brakes that are his? He included these with the sale so I was hoping to stopping by and grabbing them? Can you Call me at 310 926 9366? Thanks.
Antonio.
Old Jul 28, 2004 | 09:07 AM
neo1z's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">
lol, the helms says a lot of stuff, but you don't have to follow the helms. Some time around ball joint seperation will show you what a big hammer can do in popping out a ball joint. It's quick, easy, and painless (unless you smack something other than your ball joint). </TD></TR></TABLE>
Eh...well since it was my first time working on the S2k...I wanted to do it "by the book", so to speak
Oh well, lesson learned. Itll take an hour to do the whole thing next time.
Old Jul 28, 2004 | 12:05 PM
jdm AP1's Avatar
check spring rates and see if they fit your needs.. most people are satisfyed with anything 15-30% stiffer over stock...
if you track the car you may want a little bit more stiffnes than that though
BAMbam160
Jan 28, 2010 07:50 PM
S2Kitt
Southeast (Sales)
Jan 12, 2009 02:29 PM
IntegraLs94Cam
Honda S2000
172
May 3, 2007 05:51 AM
Chief Brody
Oct 8, 2003 07:38 AM
