D15B - serial numbers and HP's
Old Jul 19, 2004 | 09:20 PM
yecora's Avatar
Default D15B - serial numbers and HP's
Can anyone give a information about JDM D15B 130 Hp Serials - becouse some D15B has only 105 Hp's and other's has vtec-e...
And one more question - is it true, that I can't place head from JDM D15B to longblock EDM or USDM D15xx motor's becouse of diference in piston construction??
thnx in advance
EG4 with broken timing belt.
Old Jul 19, 2004 | 09:22 PM
non's Avatar
non
Default Re: D15B - serial numbers and HP's (yecora)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yecora &raquo;</TD></TR><TR><TD CLASS="quote">Can anyone give a information about JDM D15B 130 Hp Serials - becouse some D15B has only 105 Hp's and other's has vtec-e...
thnx in advance
EG4 with broken timing belt.</TD></TR></TABLE>
it's "TRUE" that "SEARCH" is your friend
Old Jul 19, 2004 | 09:30 PM
ABK's Avatar
ABK
Default Re: D15B - serial numbers and HP's (eg2R)
jdm d15b is like a vx block, susposably stronger rods. p-28 head (like z6) but better cam compared to a zex cam. makes something like 128hp. Basicly a smaller version of z6 but just as powerfull.
Yes you can put a jdm d15b head on usdm d15 or d16 as long as the piston has 4 valve reliefs. Some cx motors only got 2
Old Jul 19, 2004 | 09:35 PM
Tad's Avatar
Tad
the d15b,
its rated at 130ps, not hp,
that calculates to 128.22 exactly
not that ratings are exact, but if they were thats what it'd be
Old Jul 20, 2004 | 06:37 AM
yecora's Avatar
Default Re: D15B - serial numbers and HP's (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK &raquo;</TD></TR><TR><TD CLASS="quote">jdm d15b is like a vx block, susposably stronger rods. p-28 head (like z6) but better cam compared to a zex cam. makes something like 128hp. Basicly a smaller version of z6 but just as powerfull.
Yes you can put a jdm d15b head on usdm d15 or d16 as long as the piston has 4 valve reliefs. Some cx motors only got 2</TD></TR></TABLE>
I've search out the JDM EPC, and found that piston (on d15b 130 hp) part number is different from the part number of JDM non-vtec d15b.
So, really I'm in trouble - I have now the EDM EG4 Civic with D15b2, and I can swap the head with all the necessery equipment like tranny, fuel rail, etc, OR I can swap the whole motor with the long block and transmission.
PRO - to the first variant - not need to do corrections to the docs, in russia this is a serious problems.
Contra - to the first variant - I'm really do non know anybody in Moscow who can (or try) to do this swap...
Second variant - is twice expensive (about 1000 usd for all with work) but 100% successful...
Guys, If anyone do this head swap, or may be see anywhere DETAILED instructions, please help.
I understand that SEARCH is the best friend of LAMER, but may be i'm not so much now (in termins, words) to enter correct string of words to search right infos...
So, guys, help please
tanksmokin18
Jan 21, 2011 10:28 AM
1boostedcivic
Oct 15, 2006 08:10 PM
Kashi
Feb 11, 2005 09:40 AM
NINJASPY
16
Nov 25, 2003 08:19 AM
Steve90HB
Aug 25, 2003 02:08 PM
