? itr im
Couple of questions.
I'm gathering parts to install itr manifold on b16.
The car is obd0, i'll be using 95 gsr fuel rail.
The iacv valve is from a 95 b16 obd 1 and the iat sensor came with the im, it's obd 2.
Will these sensors work on obd0?
What o-rings for the injectors do i from honda to make this happen?
I'll be using the 1st gen b16a injectors.
I searched, but these are the ?'s that i still have.
TIA
Modified by eda6 hb at 3:40 PM 7/20/2004
TIA
I would guess that the sensors will be fine, and I would think that the inj seals will be fine too, seems like the same part #s for both, if they dont fit try 90-91 teg seals.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi »</TD></TR><TR><TD CLASS="quote">I would guess that the sensors will be fine, and I would think that the inj seals will be fine too, seems like the same part #s for both, if they dont fit try 90-91 teg seals.</TD></TR></TABLE>
From searching I learned that all b-series motors come with same size injectors cc wise.
Hopefully it's the same with o-rings.
Thankx bro :thumbup
Thankx bro :thumbup
