Twm jumps on board.
Old Jul 19, 2004 | 08:11 PM
Tbone's Avatar
Default Twm jumps on board.
I was just on thir site and noticed that they sell an external rear spray injector kit which move the inj upstream the throttle plate.. Looks like they have been paying attention
http://www.twminduction.com/Th....html
http://www.twminduction.com/Th...7.jpg
Old Jul 19, 2004 | 08:15 PM
jaydmcrx's Avatar
I understand what it does, and how it works. But im not really sure what the advantages are on the second set of injectors. Can somebody shine some light on this for me if they dont mind. Or do i have to search it. Cuz im really lazy, and i dont really feel like it. Not really what it does, but more why you need it.
Old Jul 19, 2004 | 08:21 PM
dsadas89das78934's Avatar
i dont think it's an extra set of injectors, it 'moves' your injectors to that position.
having the fuel injectors farther away from the ports helps with fuel atomization, which in turn improves horsepower. the downside to this is that idle quality is significantly decreased the farther away you place the injector
Tbone's Avatar
Default Re: (jaydmcrx)
They do this because it lets the fuel and air mix better for better atomization and it also works like a waterinjection system and cools the runners dramaticly. .. see below for injector info. Edited after talking with TWM
Modified by Tbone at 5:34 PM 7/20/2004
Old Jul 19, 2004 | 08:23 PM
dont ya just love posting at the same time as someone else....
Old Jul 19, 2004 | 08:30 PM
jaydmcrx's Avatar
Ahh. I thought you kept the first set of injectors, and a second set sprayed into the horns. Thats pretty trick. Anybody using these on the streets, or wouldnt it be reccomended.
Old Jul 19, 2004 | 10:15 PM
RenoRacing's Avatar
I cant imagine that it would be too streetable at all! gas mileage would be hilarious! I'd like to see them present some numbers of their standard setup compared to this setup on the same motor with tuning. I wonder if we're talking a few hp or upwards of 5 or 10?
i remember seeing this picture a while back on someone's setup on here.
Old Jul 19, 2004 | 11:38 PM
X-Static's Avatar
Default Re: (RenoRacing)
i'd love to just stand there and watch it spray...something you never get to actually see
anyone have a vid?
Old Jul 20, 2004 | 02:35 AM
NW94RS
Guest
Posts: n/a
Default Re: (X-Static)
they were using this kind of setup on a f1 car a while back i guess they saw a dramatic increase of power with this setup
Old Jul 20, 2004 | 02:39 AM
GOLDBERG's Avatar
Default Re: (NW94RS)
hmmmm..hows it idle????not very much suckin there
Old Jul 20, 2004 | 07:33 AM
IN VTEC's Avatar
Default Re: (GOLDBERG)
My guess is that you have to crack the throttle plates open a little at idle by adjusting the throttle linkage and recalibrating the TPS.
Old Jul 20, 2004 | 07:37 AM
Tbone's Avatar
Default Re: Twm jumps on board. (Tbone)
Toda itb's are before the plate like these and people have no idle issues with them. Think about how strong the vacuum is at idle around the plate.
Modified by Tbone at 2:23 PM 7/20/2004
Old Jul 20, 2004 | 07:44 AM
WAFFLES's Avatar
I'm lost. If the injector is between the firewall and the butterflys, then how does the car idle?
Old Jul 20, 2004 | 08:00 AM
skunked's Avatar
Since you brought this to our attention Tbone....are you gonna dyno some for us?
Old Jul 20, 2004 | 08:49 AM
Tbone's Avatar
Default Re: Twm jumps on board. (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">Since you brought this to our attention Tbone....are you gonna dyno some for us? </TD></TR></TABLE>
I want to Who's in tight with Twm.
Old Jul 20, 2004 | 09:30 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone &raquo;</TD></TR><TR><TD CLASS="quote">
I want to Who's in tight with Twm.</TD></TR></TABLE>
yeah, that's the real question.
Old Jul 20, 2004 | 01:09 PM
Tbone's Avatar
Talked to Twm today.They are in fact secodary injectors and you need to run a total of 8 smaller inj's and you will need a full stand alone to controll them. Garry and Hank at Twm are very nice guy's and are willing to feild any questions you can throw at them.
Modified by Tbone at 5:33 PM 7/20/2004
Old Jul 20, 2004 | 01:20 PM
RenoRacing's Avatar
damn, doesn't look like it'd be too hard of a setup to replicate for about half that price.
What the crap... you changed your post..... lol
Old Jul 20, 2004 | 01:26 PM
DonF's Avatar
Default Re: Twm jumps on board. (RenoRacing)
Or you need a DTA, Motec system that you can switch injectors at a given RPM. Then you can use a stock set at the head or throttle plate and switch to the other set, outboard, at a given RPM 4000 or 5000, etc. this gives you the best of both worlds. Tbone (904) 378-4480 or E-mail IM is hit or miss. Thanks
Old Jul 20, 2004 | 09:15 PM
JDMorgan's Avatar
how does the gas not spray all over the firewall? if ur accelating at a quick rate i would think your acceleration rate of the car would be greater than that of the fuel.
Old Jul 20, 2004 | 09:33 PM
JDMlyfestyle's Avatar
they did this on a 200 WHP build in HCI mag. and i think they gained like 13 whp by moving the injectors in front of the velocity stack
Old Jul 20, 2004 | 10:31 PM
Suprdave's Avatar
Default Re: (KraZEtEggIE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE &raquo;</TD></TR><TR><TD CLASS="quote">how does the gas not spray all over the firewall? if ur accelating at a quick rate i would think your acceleration rate of the car would be greater than that of the fuel.</TD></TR></TABLE>
Nope...gotta remember that the fuel\injectors\etc are traveling at the same speed as the rest of the car.
Old Jul 20, 2004 | 10:36 PM
Default Re: (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">
Nope...gotta remember that the fuel\injectors\etc are traveling at the same speed as the rest of the car.</TD></TR></TABLE>
You also gotta remember that the Vaccum force from the engine will also bring the fuel into the motor instead of the firewall
Old Jul 21, 2004 | 06:34 AM
6SPD_EK's Avatar
i thought this set up was too dangerous for you ...& i have that HCI article where 14+ whp were gained from a similar set up on a built b16a (no change to timing or fuel maps)
https://honda-tech.com/zerothread?id=663761
Old Jul 21, 2004 | 10:32 AM
Tbone's Avatar
Default Re: Twm jumps on board. (adirondackR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=663761</TD></TR></TABLE>
I never said it would be to dangerous for me , I just asked/noted that it looked dangerous. Which TWM agree's they dont even sell them to people who mention Street car..lol
