FT / FS 96 red EK b16/b18c swap
Located in SOCAL
My car is a 96EK w/
B16 Head
Type-R Cams
AfterMarket Dual Valve Springs" I belive it was JE " Can take the car to 9k+ no problem.
Apex N1 Pipe w/ spoon style exhaust
Stock Air Box with K&N
DC 4-2-1 Header
GSR Bottom End
SI cluster
SI Front Seats
Type-r Steering Wheel
GSR Blade Rims
Carbon Fiber Hood
Carbon Fiber Wing
Ground Control Coil Over
Spoon Style Rear Tie Bar
Stiff Stiff springs
Pillar Bar "Great for hanging your clothing on the way to work"
JUN ECU
Will Also give you a stock B16 bottom end "B16 was parted for pistons, But I still have everything you need to finish the b16 if you want it, its yours !"
Car has also been stripped
I'm looking for a AE86 or a 92 and below 240sx... Would also like a 92 and below civic hb and Nice CRX's
[IMG][/IMG]
Modified by DC24jooo at 8:08 AM 7/22/2004
Modified by DC24jooo at 8:09 AM 7/22/2004
My car is a 96EK w/
B16 Head
Type-R Cams
DC 4-2-1 Header
GSR Bottom End
SI cluster
SI Front Seats
GSR Blade Rims
Carbon Fiber Hood
Carbon Fiber Wing
Stiff Stiff springs
JUN ECU
[IMG][/IMG]
Where are you located? Can I come check it out? I have cash in hand. Also, If I pick up the B16 bottom end, does it go all the way down to the oil pan? Do you have Type-R valves and springs as well?
How is it that you could take it up to 9k? The GSR valvetrain isn't suppose to go up to 9k (it's limited to 8k) and ITR cams could make power up to 7900.
Modified by Track 11 at 1:59 AM 7/21/2004
My car is at the shop right now.. Everything is getting gone over. All the gaskets and vavles basicly in the car r getting replaced. B16 Pistons with new piston rings are getting droped in. Should gain some more Hp/Tq from it. I should get the car back saterday and I can take more pics.
Ill trade you for my white 92 Civic HB that has a very nice motor in it. PM for details on the motor. HB has tokicos ground controls, ST sway bars front and back. Del sol seats inside, jdm headlight, CF hood, JDM Tomei steering wheel, Greddy exhaust, PM for more details on motor and whatever else. I am in Socal.
