92 integra gsr turbo..
I don't know much about hondas but i'm doing some research for a friend so hopefully you guys can help me out,
He's got a 92 integra gsr with the 1.7 liter engine, this is the B17A correct? How strong is the bottom end on one of these, will it hold up to much boost in stock form? Do you have any general information that might be helpful about the B17A?
Maybe you guys could send me a link with some general honda performance information like differences between engines etc. because i can't seem to find anything like that.
Thanks
Thanks
Yes, you are correct.
It is the 1.7L B17A1 motor, available in the 1992 through 1993 GSR's
160HP @7600rpm in stock form
117ft-lbs at 7000rpm
1678cc displacement
9.7:1 compression ratio
Depending on the condition of the motor (i.e.: rings, cylinder walls, other wear items), it could vary how much power the block can endure. Assuming everything is in perfect condition, I'd say around 8-10psi tuned. This is the same number that the newer Integras also can take stock.
Most everyone will tell you to search the site. If you want to know more about turbo's, search the Forced Induction forum.
If you want to know more about engine available for Hondas like you asked, check out this site: http://www.bseries.net/html/specs/benginespecs.php
1678cc displacement
cowboys22cardinals22
Apr 29, 2008 09:46 AM
