DPFI TO MPFI CONVERSION
Old Jul 19, 2004 | 06:45 PM
crx-t's Avatar
Default DPFI TO MPFI CONVERSION
PERFORMED THE CONVERSION TO MPFI SYSTEM THE ENGINE STARTS UP FINE AND IDLES GREAT, BUT WILL NOT REV OVER 3000 RPM IT SPUTTERS LIKE A REV LIMITER WOULD.THE CAR IS A 91 CRX 1.5 WITH A TURBO.I TRIED ANOTHER ECU AND IT DOES THE SAME.DOES ANYONE HAVE ANY ANSWERS?
Old Jul 19, 2004 | 10:16 PM
locash's Avatar
Default Re: DPFI TO MPFI CONVERSION (crx-t)
Yes, bad distributor wiring. Double check it, you may have a pair of sensor wires backwards or swapped with another distributor sensor.
Old Jul 21, 2004 | 04:31 PM
crx-t's Avatar
Default Re: DPFI TO MPFI CONVERSION (locash)
TRIED SWAPPING THE SENSOR WIRES IN THE DIST,NO CHANGE.COULD IT BE A BAD DIST? ANY THING ELSE I SHOULD CHECK?
90R3x
Jul 15, 2014 05:20 AM
riftonthemind057
Mar 27, 2008 01:08 PM
minime-civic
Jun 5, 2007 12:25 PM
davidcrx89
Jul 5, 2006 09:48 PM
acurateggy93
Jul 26, 2005 08:06 PM
