car still isnt working please help
Old Jul 19, 2004 | 03:40 PM
cademan's Avatar
Default car still isnt working please help
ok so my car still will not start. when i turn the key nothing happens other than the dash lights come on. i know it isnt the starter or battery i have tested both. also when the battery is hooked up my brake lights come on, so there is obviously a live wire or blown fuse or something(any ideas what fuse or where i should check or anything to help?). the car will roll start so im also guessing its not the alternator. how likely is it that its the ignition switch, and is this somethin that would just suddenly go out cause that is what happened? please help me i need this car rolling asap.
thanks
Old Jul 19, 2004 | 03:42 PM
bambam's Avatar
Check the blk/wht wire going to the starter and make sure it is snug.
It sounds more to me like you are missing a ground. Check your ground on ur valve cover, thermostat housing, and from ur tranny to ur battery.
Then you can go ahead and check ALL ur fuses under the hood and dash. Replace the blown ones.
ej2 coupe
11
Jan 11, 2008 03:38 PM
yee SERIOUS
14
Nov 12, 2006 01:30 PM
90Integra
Aug 6, 2006 01:01 PM
WAT THA!!!
Oct 8, 2004 01:08 PM
BoM
Feb 19, 2002 10:09 PM
