question for itr usdm abs and jdm itr abs?
Old Jul 19, 2004 | 03:03 PM
jdmekrsi's Avatar
Default question for itr usdm abs and jdm itr abs?
hello i have a 01 itr well heres the thing i bought a front not rear 98 jdm itr 5 lug it did not have abs on it well my mechanic made the tread to bolt on the stock itr usdm abs and the abs light is on he is telling me that the jdm sensor is a diffrent size because of the axles being bigger are they the same or do i have to get the jdm sensor because right now im using the usdm abs sensor on a jdm 5 lug let me know by the way its only the front 5 lug well let me know asap thanks
Old Jul 19, 2004 | 03:06 PM
ThePro's Avatar
Default Re: question for itr usdm abs and jdm itr abs? (jdmekrsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmekrsi &raquo;</TD></TR><TR><TD CLASS="quote">hello i have a 01 itr well heres the thing i bought a front not rear 98 jdm itr 5 lug it did not have abs on it well my mechanic made the tread to bolt on the stock itr usdm abs and the abs light is on he is telling me that the jdm sensor is a diffrent size because of the axles being bigger are they the same or do i have to get the jdm sensor because right now im using the usdm abs sensor on a jdm 5 lug let me know by the way its only the front 5 lug well let me know asap thanks </TD></TR></TABLE>
I'm going to try to clarify this. Tell me if I am correct.
You have a 2001 Integra Type R and you went out and bought a JDM front suspension. I can only assume it's because you wanted the larger diameter axels and spline (although with as hard as those axels are to find I can't figure why). What happened is the JDM suspension was Non-ABS so you had your USDM ABS system retrofitted onto your JDM suspension.
Now the ABS light stays on indicating a problem with the ABS system. The mechanic that did the work is telling you it's because the JDM ABS sensor is a different size and the USDM sensor won't work with the suspension.
Am I correct?
Old Jul 19, 2004 | 03:50 PM
jdmekrsi's Avatar
Default Re: question for itr usdm abs and jdm itr abs? (ThePro)
well heres the thing my usdm itr 5 lug was taken off for a 4 lug on the track because i wanted slicks and i had left it in my backyard and it was stolen i bought a 98 itr 5 lug because my friend had it from a front clip he bought so thats reason i have this problem so your telling me that the jdm one does not come with abs??
Old Jul 19, 2004 | 03:52 PM
jdmekrsi's Avatar
your correct about that question what can i do will the abs still work?
Old Jul 20, 2004 | 06:56 AM
ThePro's Avatar
No, the JDM ones do come with ABS, but it was an option on the JDM ITR's. It should work. If you look at someones ABS system, the abs sensor just sits at the bottom of the hub and isn't attached to the axels in any way. So I'd call BS on the guy, but I'm just shooting from the hip here.
Old Jul 20, 2004 | 02:30 PM
jdmekrsi's Avatar
well what can i do for now i have to go to state ref and i have the abs sensor on!
Old Jul 20, 2004 | 02:42 PM
ThePro's Avatar
State ref? I assume that's an inspection.
I don't know how thorough they are with inspections where you are at, but I'd just take the light out of the gauge cluster behind the ABS light.
raverx3m
Dec 24, 2012 01:16 PM
mikeweb
Feb 24, 2004 12:27 AM
boostedsol
Oct 22, 2003 07:37 PM
yaksplat
Aug 23, 2001 08:42 AM
