2003 K20 JDM ITR vs 2003 K24
Old Jul 19, 2004 | 02:37 PM
StarRizer's Avatar
Default 2003 K20 JDM ITR vs 2003 K24
Would the head from a 2003-2004 K20 type-r accord fit onto a K24 Accord engine? Or would it not be compatible because of the differene in displacement?
Also, if I interchanged the ECU from the Accord type-r in Japan with my own accord's chip, would I need to make further adjustments? What would they be?
Just curious to see if anyone knows
Thanks
Old Jul 19, 2004 | 04:14 PM
fw190bvi's Avatar
Default Re: 2003 K20 JDM ITR vs 2003 K24 (StarRizer)
head should swap on fine.....being that every other honda series has interchangeable parts (not to mentio all the accors-series interchangeability)
Old Jul 19, 2004 | 05:20 PM
StarRizer's Avatar
Default Re: 2003 K20 JDM ITR vs 2003 K24 (fw190bvi)
Really? Cool. Thanks
What about the ECU from the current JDM Accord type-r? Would that be screwed up from the change in displ.?
Old Jul 19, 2004 | 05:23 PM
fw190bvi's Avatar
there is no accord type r
Old Jul 19, 2004 | 05:32 PM
StarRizer's Avatar
I'm talking about this accord. Check it out:
http://www.honda.co.jp/auto-lineup/accordeuro-r/
and this:
http://www.honda.co.jp/auto-li....html
it's the current accord type-r
Old Jul 19, 2004 | 05:51 PM
madd's Avatar
euro-r != type-r
Old Jul 19, 2004 | 06:22 PM
StarRizer's Avatar
Default Re: 2003 K20 JDM ITR vs 2003 K24 (madd)
Yes,
but are the computer chips swapable without any problems? That's what I'm trying to find out
Old Aug 3, 2004 | 05:43 AM
projectpat817's Avatar
if ur gonna change out the head to a k20 then you will need a k20 ecu...
but i dont think there are 03-04 k20 ACCORD type-r's...? all the new accords are all k24 (i4) or j30's (v6)...
i don't see why you would to change out the head for another accord head... most ppl change it out for a rsx type-s head (k20a2)
Old Aug 5, 2004 | 06:05 AM
brian g's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StarRizer &raquo;</TD></TR><TR><TD CLASS="quote">Would the head from a 2003-2004 K20 type-r accord fit onto a K24 Accord engine? Or would it not be compatible because of the differene in displacement?
I believe you're going to run into a problem with the tops of the pistons on the Accord K24. The combustion chamber on the K24A4 engine is larger and I believe the piston protrudes into the head. You can bolt a CRV K24A1 block to an Accord Euro R (or RSX/Integra Type S/R) head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StarRizer &raquo;</TD></TR><TR><TD CLASS="quote">Also, if I interchanged the ECU from the Accord type-r in Japan with my own accord's chip, would I need to make further adjustments? What would they be?
Thanks</TD></TR></TABLE>
You'll need to do some wiring changes to the Accord and use an RSX /CRV/Civic Si ECU modified by Hondata. This may cause some problems with some other systems on your car.
brian g
Weel
Dec 5, 2022 08:11 AM
withoutshore
Mar 19, 2007 08:20 AM
H22CD
Sep 18, 2006 08:29 AM
DrunkNRacer
Feb 10, 2003 08:25 PM
