95 GSR didnt pass smog....WTF????
Old Jul 19, 2004 | 02:09 PM
TRAY's Avatar
Default 95 GSR didnt pass smog....WTF????
Just took my car in for a smog check and bam didnt ****** pass.....ARRRRRRRR
at 15 mph the HC (PPM) max says 90 and mine was 119
does anybody know what this car be?????
Old Jul 19, 2004 | 03:01 PM
Mt3c's Avatar
25 Year Member
Default Re: 95 GSR didnt pass smog....WTF???? (TrayDay2K1)
from all the smog threads that have been posted, you should search.
or at least give us the status of your car.
list engine mods
maintenance (oil, plugs, cap, rotor, wires)
timing
how long did you warm the car?
and anything else that may be relevent.
the more info you provide, the better you can be helped.
edit: here is a link that may be helpful... https://honda-tech.com/zerothread?id=701236
Old Jul 19, 2004 | 03:09 PM
quikrpm'z's Avatar
fuel injector, did you change your plugs recently.
Old Jul 19, 2004 | 03:14 PM
TRAY's Avatar
Default Re: 95 GSR didnt pass smog....WTF???? (quikrpm'z)
the car is stock....i barely warmed it up....the guy at the smog place let it run for like 10 minutes sitting before he did the smog you think this could have been bad??
i changed my plugs last month...
Old Jul 19, 2004 | 03:16 PM
NightRiderS2K's Avatar
In-N-Out Burger
<FONT SIZE="6">TrayDay2K1</FONT>
My old thread might help you...
https://honda-tech.com/zerothread?id=895526
I was able to pass smog after the 2nd try with the help of HT people.
NRg
Old Jul 19, 2004 | 05:16 PM
TRAY's Avatar
Default Re: 95 GSR didnt pass smog....WTF???? (NightRider-gsR)
yea i read you post....whats ISOheet? and does 89 really help i am running 91 all the time...im gonna go get a new o2 sensor soon and drive around the freeways before my next test...im so ****** pissed i was gonna sell my car today and it didnt pass RRRRRRRRRRRRRRRRRRRRRRRRR
Old Jul 21, 2004 | 02:55 AM
In-N-Out Burger
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrayDay2K1 &raquo;</TD></TR><TR><TD CLASS="quote">yea i read you post....whats ISOheet? and does 89 really help i am running 91 all the time...im gonna go get a new o2 sensor soon and drive around the freeways before my next test...im so ****** pissed i was gonna sell my car today and it didnt pass RRRRRRRRRRRRRRRRRRRRRRRRR </TD></TR></TABLE>
ISOheet mainly contains Isopropyl alcohol. It will help rid of any condensation or water build up in your fuel system which can often cause your HC readings to go high... With water in your fuel system, there will be a higher amount of unburned fuel, thus HC meaning Hydro Carbons.
A bad O2 sensor can really make you fail smog...
<FONT SIZE="4">Some words of advice:</FONT>
Instead of running 89 like I did, you can skip the ISOheet and just run a fresh full tank of 87 octane. MAKE SURE your stock air filter is clean!! Make sure your spark plugs are gapped to 1.3 mm. Be sure to change your O2 sensor...
I got mine here:
http://www.groupbuycenter.com/buy.aspx?id=15568
Run FRESH fuel (91 octance or 93 whichever is available) prior to retesting. Also, before you retest drive the car hard on the freeway or street to make the CAT really really hot.... arrive at smog place and DO NOT TURN THE CAR OFF... step out the car and let the smog guy do his thing.
Good luck!
NRg
Old Jul 21, 2004 | 09:31 AM
TeggyRacer613's Avatar
I bought an gs that apparently had failed smog 3 times prior to me owning it...well, what I did was run a fuel system additive I got from Pep-Boys for 6 bucks on a 3/4 tank of 92. I made sure to replace my cone filter (cai) and cleaned my injectors. I also checked the timing. And I had no problems passing.
I had failed in my H22/Crx also...I followed the ^^ steps with the jdm h22 and passed with flying colors...I was shocked! I thought I was gonna have to go the illegal route. So just follow those steps and you WILL pass. The stuff is calle Gaurantee Emissions Pass and its in a black/grey pakage..in a little cardboard box. Good luck and keep us posted.
Old Jul 21, 2004 | 12:51 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
So why would you want to run a lower octane gas, is it so the knock sensor retards the timing? Why not just back off the ignition timing to +14 (spec is +16 +/- 2 degrees)?
Old Jul 21, 2004 | 02:04 PM
In-N-Out Burger
Default Re: 95 GSR didnt pass smog....WTF???? (PatrickGSR94)
Lower octane, cleaner burn... or is that not right?
Old Jul 21, 2004 | 04:03 PM
B2FiNiTY's Avatar
On a gsr, it would ping like a ****. Avoid running lower octane.
Old Jul 21, 2004 | 07:39 PM
daLixz25's Avatar
higher octane is a cleaner burn.
Old Jul 21, 2004 | 09:45 PM
B-money's Avatar
Default Re: 95 GSR didnt pass smog....WTF???? (daLixz25)
Run your car for a long period of time before you get it smogged, The hotter the cattalitic converter gets the more effective it becomes in cleaning the gasses. so drive it around a lot before you take it to the smog check.
Old Jul 22, 2004 | 12:07 AM
DolphinaVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daLixz25 &raquo;</TD></TR><TR><TD CLASS="quote">higher octane is a cleaner burn.</TD></TR></TABLE>
If you have the appropriate compression it is. If you put 91 in an LS motor, you wouldn't have enough compression to completely burn all the fuel. I would almost think 89 in a GSR would be optimal for a smog test, as the GSR's 10:1 compression isn't exactly sky high enough to cause bad detanation with lower octanes.
Also, you can't go wrong with 3 bottles of HEET in an 1/8 tank of gas. The alcohol will result in a cooler, cleaner burning mixture that will surely pass smog.
Hope that helps...
Old Jul 22, 2004 | 07:02 AM
In-N-Out Burger
Default Re: 95 GSR didnt pass smog....WTF???? (B-money)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B-money &raquo;</TD></TR><TR><TD CLASS="quote">Run your car for a long period of time before you get it smogged, The hotter the cattalitic converter gets the more effective it becomes in cleaning the gasses. so drive it around a lot before you take it to the smog check. </TD></TR></TABLE>
Same old advice that's been said before earlier...
Some people just like to instantly hit, "REPLY".
Old Jul 28, 2004 | 05:24 PM
TRAY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightRider-gsR &raquo;</TD></TR><TR><TD CLASS="quote">
I got mine here:
Good luck!
NRg</TD></TR></TABLE>
cool man just got home from outta town gonna get some ISHSHEEEEEIIIIIIITTT and change the o2 sensor...also gonna adjust my timing( i had it advanced from the 1/4) and new plugs..thanks guys and wish me luck!
Lineman
May 18, 2017 07:00 PM
redDAinteg
Sep 13, 2012 08:14 PM
21ACEKING
Aug 9, 2012 09:49 AM
mreed
Nov 29, 2010 09:44 PM
msgmkr
Jun 1, 2010 12:34 AM
