dpfi to mpfi european HELP HELP
i am doing a dpfi to mpfi swap on a european civic hatchback dxi (93) d15b2 engine with dpfi because i live in the Netherlands. I am using all the d16a6 parts,intake manifold, distributor, resitorbox and pm6 ecu, after doing the swap my car won' t start. The problem is normally i have to check my ecu codes, on the dash (check engine light). I jumped the connector but no codes. The led on my ecu gives codes but those are verry strange 10 and 13 short blinks. What should i check, my engine light codes or those on the ecu. Maybe ecu broken!!!! And what can i do about the fact my car won't start. I got sparks but the sparkplugs are dry , so i think no fuel (fuel pump works), start motor runs
PLEASE HELP
Jelger
PLEASE HELP
Jelger
I thought 1 to 9 blinks means code 1 to 9, 1 long blink means code ten.
code 12 is a long blink en then two shorts ones, but never 12 shorts ones if i am correct?
88crx Osaka
Aug 20, 2011 10:42 PM
001020
11
Sep 7, 2005 07:44 AM
BigMig
May 10, 2003 06:01 PM
