Something madd weird just happened to my car
I was driving my car. I just finished spraying my rims and I didnt drive the car for 2 days. Anyway today I drive it and after first gear whatever gear I put it into that shifter shakes back side to side. I cant even control it. The whole car would shake too. It was almost like the car was shaking from side to side as well as the shifter. I was shittin bricks cuz I didnt know what was going on so I drove to the nearest shop. I left it there for an hour and the guy test drove it and comes back to tell me nothing was happening and that it was ok. I didnt believe him but when I got in my car and started to drive away nothing hapened. Wtf was going on? Anybody ever had this problem before?
its trolls....
bad gas?? Was it like an earthquake?
were you drivin on messed up pavement..I dont think tegs do good off road..
hope it dont happen again I am sure it must of sucked
no codes. It never did this before. I drive through the same street like a million times and this never happened. It almost felt like someone was under the car shaking the linkage or something but that doesnt explain the whole car vibrating at the same time the shifter was...
if you pulled your wheels to paint them...make sure all the lugnuts are tightend.
Sounds stupid but 2 of mine came loose and the slightest wiggle room can make a HUGE difference.
This might sound weird but check your axles. my right axle went out 4mo ago and never once showed any sighns of popping or anything when I would turn. I was driving about 1 week before it went out and all the sudden the whole car started to rock and the steering pulled hard to the right for about 4 seconds then it stopped. It happend about 4 more times after that and I still had no idea until snap the whole axle broke with no warning besides the sudden walble and pulling kind of like what you sayed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mparker »</TD></TR><TR><TD CLASS="quote">This might sound weird but check your axles. my right axle went out 4mo ago and never once showed any sighns of popping or anything when I would turn. I was driving about 1 week before it went out and all the sudden the whole car started to rock and the steering pulled hard to the right for about 4 seconds then it stopped. It happend about 4 more times after that and I still had no idea until snap the whole axle broke with no warning besides the sudden walble and pulling kind of like what you sayed.
same happend
</TD></TR></TABLE>same happend
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NYCz DA9 »</TD></TR><TR><TD CLASS="quote">damn... so what should I look for in the axles? Could it have failed internally(inside the boot)?? Maybe its starting to fail but how do I know which one to change?</TD></TR></TABLE>
They are easy enough to change, just do both.......
Dont help this scammer.
https://honda-tech.com/zerothread?id=927172
haha good for you, i hope your car just falls apart while your driving with your baby in it and you both die.
Veritas-Aequitas
Jun 8, 2005 04:20 PM
