Solid aluminum dowel pin or OEM aluminum roll pin for shift linkage?
The past two roll pins were a bitch and a half to get out, even with the right sized punch.
I'm sitting here with a solid pin and questioning using it.
Should it be obvious to me? ~Because it's not.
IDK, aluminum is pretty weak and thats a high stress area. that is a tiny AL pin to transmit all that force. Do it right and use the steel pin IMO, its not hard to get out with the proper sized punch.
I put the standard pin in it simply because it works somewhat like a spring.
I'm interested though PHiZ, how do you knock it out from above? Isn't the transmission in the way?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .brad »</TD></TR><TR><TD CLASS="quote">I put the standard pin in it simply because it works somewhat like a spring.
I'm interested though PHiZ, how do you knock it out from above? Isn't the transmission in the way?</TD></TR></TABLE>
First I disconnect the stabalizer bar, then I can move then I can rotate the shifter mechansim clockwise, maybe 15-30 degrees. Then I electrical tape my punch into a socket, and put all my extensions and cheater bars together, to make about a foot and a half extension. Then I go in through the top.
The lower tranny mount has to be manuvered around, but my method lets you really swind a hammer.
-PHiZ
I use SAE punches too, because that's all I could find, so I have to switch punches mid way through, but
-PHiZ
rasinhell
Jan 14, 2005 06:25 PM
That is the trick.
