Where to buy ports
Old Jul 19, 2004 | 11:48 AM
phreakmang's Avatar
Default Where to buy ports
Building a sub box and need to get 2 of the plastic ports. Where is a place to buy these online?
Old Jul 19, 2004 | 11:56 AM
hybridzOr's Avatar
Default Re: Where to buy ports (phreakmang)
any audio store will have them, check around for mom & pop shops.. they should have some in stock.
why not go sealed?
Old Jul 19, 2004 | 11:57 AM
phreakmang's Avatar
Default Re: Where to buy ports (Hybrid Racer.)
was recommended to me to go with ports.
1000w audiobahn sub, custom fiberglass enclosure i'm making in the spare tire well and a 1000w mono audiobahn amp.
Old Jul 19, 2004 | 12:19 PM
pnthr30's Avatar
Crutchfield has them..........
Old Jul 19, 2004 | 12:54 PM
rcurley55's Avatar
New User
Default Re: Where to buy ports (pnthr30)
pvc pipe - available at any hardware store - it works wonders!
Old Jul 19, 2004 | 02:49 PM
nsxxtreme's Avatar
Default Re: Where to buy ports (rcurley55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcurley55 &raquo;</TD></TR><TR><TD CLASS="quote">pvc pipe - available at any hardware store - it works wonders!</TD></TR></TABLE>
4" PVC is what i use. http://www.partsexpress.com should also cary ports.
Old Jul 20, 2004 | 10:23 PM
Downs's Avatar
I vote Crutchfield as well. They aren't too expensive anyways.
Sealed and ported merely depend on preference/type of music that you listen to.
Old Jul 21, 2004 | 07:31 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">
4" PVC is what i use. http://www.partsexpress.com should also cary ports.</TD></TR></TABLE>
Pvc drain pipe 94
Old Jul 21, 2004 | 08:20 AM
hoggy's Avatar
Default Re: Where to buy ports (Downs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Downs &raquo;</TD></TR><TR><TD CLASS="quote">
Sealed and ported merely depend on preference/type of music that you listen to.</TD></TR></TABLE>
I disagree with this. A well built ported box can sound just as good as a well built sealed box. The main problem is there are very few people in most areas that can even design a proper ported enclosure. Its a proven fact that ported is louder and its a strong belief by many that the gains you get from going ported far outweigh what you lose in SQ. The SQ you lose is not usually noticeable unless you are an audiophile and are extremely picky.
BTW, I use PVC piping for daily driver SPL boxes and for my car I smooth them a lot on the edges.
Old Jul 21, 2004 | 10:46 AM
rcurley55's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Downs &raquo;</TD></TR><TR><TD CLASS="quote">Sealed and ported merely depend on preference/type of music that you listen to.</TD></TR></TABLE>
you have it backward...
select the enclosure to match the woofer, select the woofer to match the music/goal
some subs can work well in multiple applications, but you can't select the box without thinking about the sub first...it's putting the wagon before the horse...
Old Jul 21, 2004 | 10:52 AM
phreakmang's Avatar
so...
audiobahn 1000w sub (forget model, probably 1 year old) in a fiberglass enclosure in my spare tire well.
ported/not ported?
Old Jul 26, 2004 | 05:42 AM
hoggy's Avatar
First you need to estimate how much air space you will have. Then you need some specs on the subs recommended enclosures.
z395civic
Audio / Security / Video
11
Nov 3, 2008 12:10 PM
DailyDrivenDB8
Nov 29, 2006 11:58 PM
DJHyperXK2004
Aug 12, 2005 11:03 AM
TooCoolToSpool
12
Aug 11, 2005 12:35 PM
NavyHonda95
Oct 14, 2004 06:43 PM
