Take out climate control and other vents
94-up....here's how
Climate control:
*Carefully pry out the hazard and defroster button with a small screwdriver. You will notice the grove on the bottom of the button. Pry from there.
*Remove the 2 phillips head screws behind the 2 buttons you just removed.
*Disconnect the cable that connects to your condenser box. That cable can be found under the passenger side area of the dash, behind the glove box.
*Disconnect any plugs connected to the A/C controls and BAM! You're done.
Pass. Side vent should just pop out if you pry.
Driver's side vent:
*Remove the lower panel of the dash (that's the one with the fuse box cover and coin tray)
*Pry out the moonroof switch, carefully
*Remove the Phillips head screw behind where the switch used to be
*Pry off the vent!
Climate control:
Driver's side vent:
*Pry off the vent!
Zoso1977
Nov 6, 2004 10:57 PM
LSegHatchy
Aug 4, 2004 06:45 PM
