Question: 95 Accord 5 spd Conversion
Old Jul 19, 2004 | 03:13 AM
b18b1r's Avatar
Default Question: 95 Accord 5 spd Conversion
I have a 95 Accord EX Sohc VTEC. Do I have to change the ECU if I convert my car from automatic to Manual?
thanx!
Old Jul 19, 2004 | 03:46 AM
nnyCD7's Avatar
Default Re: Question: 95 Accord 5 spd Conversion (b18b1r)
Im pretty sure you do, I have seen this done, the hardest part was getting the clutch pedal in the right postition and all that. Hopefully someone else that knows for sure will respone, but im pretty sure you have too.
Old Jul 19, 2004 | 04:01 AM
nnyCD7's Avatar
Default Re: Question: 95 Accord 5 spd Conversion (nnyCD7)
You can get a chipped P28, and a OBD2 to OBD1 coversion, also pin 6 switched with 11.
Old Jul 19, 2004 | 06:44 AM
Nick H's Avatar
New User
yes, you have to swap the ecu out...and the pedals aren't that difficult...i personally found the most difficult part was running the shifter cables through the firewall when i helped a buddy do this swap...this swap is a lot easier with the motor removed
Turboshaft
Dec 27, 2017 12:47 PM
19HondaAccord95
Aug 28, 2012 06:48 PM
Aradin
Mar 18, 2011 01:51 AM
statik215
May 28, 2009 02:04 PM
