Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
EVO 3 seat
Old Jul 19, 2004 | 01:49 AM
greatbiggiants's Avatar
Default EVO 3 seat
Hey do you guys recomend the EVO 3 seat for me. I am 6-2 250lbs and have a 38 waist, big thighs. Also have pretty big sholders. Do you think I should stay with stock seats. ie usdm type R, delsol or CRX seats. this is my weekend car (only car) car. But i like to go to the track, back roads and would love to start autocrossing, if i could find out were they are in my city.
Old Jul 19, 2004 | 05:47 AM
George Knighton's Avatar
H-T Order of Merit
Default Re: EVO 3 seat (greatbiggiants)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greatbiggiants &raquo;</TD></TR><TR><TD CLASS="quote">Hey do you guys recomend the EVO 3 seat for me. I am 6-2 250lbs and have a 38 waist, big thighs. Also have pretty big sholders. Do you think I should stay with stock seats. ie usdm type R, delsol or CRX seats. this is my weekend car (only car) car. </TD></TR></TABLE>
I'm 6'2" and about 220. I do OK w/the EVO 2. See if you can find some at a retailer or racing shop and sit in both of them.
I'm not sure how advanced you are, but remember that when you change one thing in a car, you are frequently forced to look at other changes, too.
For example a DC2 ITR's OEM belts do not work very well w/an EVO.
Old Jul 19, 2004 | 05:50 AM
.RJ's Avatar
.RJ
Default Re: EVO 3 seat (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">For example a DC2 ITR's OEM belts do not work very well w/an EVO. </TD></TR></TABLE>
Depends on where the buckle is.
I was able to unbolt and re-use my stock buckles in the stock location with my seat mounts, and it works ok for the street. Its not any worse than the OEM seat.
Old Jul 19, 2004 | 06:20 AM
H-T Order of Merit
Default Re: EVO 3 seat (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, that helps; however, regardless of where the buckle is, the side bolsters will place the inertia-controlled belt too far off your waist for the OEM belts to work as designed.
Right?
Old Jul 19, 2004 | 06:21 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">the side bolsters will place the inertia-controlled belt too far off your waist for the OEM belts to work as designed.</TD></TR></TABLE>
Its really not that much further off than the stock arrangement.
Old Jul 19, 2004 | 08:18 AM
H-T Order of Merit
I guess we have a different frame of reference. We will have to compare notes sometime when we're in the same place.
The 1-2" difference on the left side, IMHO, would alter how the OEM safety belts respond.
Old Jul 19, 2004 | 08:19 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">The 1-2" difference on the left side, IMHO, would alter how the OEM safety belts respond.</TD></TR></TABLE>
You can re-route the belt so that its through the hole in the side bolster, if you want.
Old Jul 19, 2004 | 08:31 AM
Stinkycheezmonky's Avatar
Suspetise...
George, maybe you're 1-2" less fat than RJ?
Old Jul 19, 2004 | 08:34 AM
H-T Order of Merit
You can re-route the belt so that its through the hole in the side bolster, if you want.</TD></TR></TABLE>
Is that what you've done, then, that you're saying the bolster doesn't interfere?
Old Jul 19, 2004 | 08:37 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">Is that what you've done, then, that you're saying the bolster doesn't interfere?</TD></TR></TABLE>
Well if you route the belt that way, its inside the bolster on the left side, although it still has to go over the bolster on the left side.
I just dont think its that bad at all in its placement, especially with fixed seats.
Old Jul 19, 2004 | 08:42 AM
H-T Order of Merit
OK, well, we'll just have to compare notes and make sure each of us knows what the other's talking about the next time we're both in the same place.
Old Jul 19, 2004 | 08:43 AM
.RJ's Avatar
.RJ
How is your seat buckle on the right side attached?
H-T Order of Merit
Oh, and somebody bookmark this thread.
I think it's the only Honda-Tech thread today where people have disagreed and not engaged in verbal bombast.
Old Jul 19, 2004 | 10:44 AM
Xian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">Oh, and somebody bookmark this thread.
I think it's the only Honda-Tech thread today where people have disagreed and not engaged in verbal bombast.</TD></TR></TABLE>
So very true...
I think what RJ is trying to say is that you can unbolt the bottom of the seatbelt and run it through the lower left opening in the seat so that the lap belt sits across you... the shoulder restraint part would come across your shoulder and then over seat to reach it's upper attachment point. To me, it sounds like this would work pretty well... are you able to get the seat belt buckle through the right side opening or do you still need to run the seatbelt over the right hip bolster area?
Old Jul 19, 2004 | 12:21 PM
Suspetise...
Default Re: EVO 3 seat (Xian)
That's how mine is setup. If the Pro2000 is at all similar to the Evo-series, that should work fine. If you need to look at mine at the Expo, George, you're welcome to.
Old Jul 19, 2004 | 01:04 PM
mstewar's Avatar
it's ok.. it's just because you and RJ were basically having a conversation with just each other..
and just because george asked for it.. RJ is a st00pid head.. who would listen to that idiot..
better?
Old Jul 19, 2004 | 04:47 PM
Default Re: EVO 3 seat (mstewar)
Hey guys I an having trouble picturing what u guys are talking about . Got any pics of your belt set up.
EP3 FTW
14
Dec 2, 2007 02:34 AM
dangk
Honda Civic (2001 - 2005)
Nov 10, 2006 06:42 AM
TurboEM1
May 30, 2006 07:52 AM
built562
Jan 24, 2004 11:49 AM
qcoffey
Nov 13, 2002 04:18 PM
