FS: ProDrive Oil Pump Gear (New), GTECH Pro (Used) .... Dialup Killer
Old Jul 18, 2004 | 11:28 PM
int3gra's Avatar
Default FS: ProDrive Oil Pump Gear (New), GTECH Pro (Used) .... Dialup Killer
Brand new still in the plastic, ProDrive Oil Pump Gear $200 Shipped
I bought this for my B18B and it is confirmed by ProDrive to fit it, even though it says GSR. Should fit all B18s.
Larger Pics (HUGE):
http://67.18.162.242/~intraco/HT/CIMG0550.JPG
http://67.18.162.242/~intraco/HT/CIMG0549.JPG
http://67.18.162.242/~intraco/HT/CIMG0548.JPG
http://67.18.162.242/~intraco/HT/CIMG0547.JPG
<U>Here is some info on the gears, if you don't know what they are:</U>
ProDrive Oil Pump gears are precision machined and ground out of solid steel to insure longer life than inferior quality sintered metal OEM gears. There are many factors that contribute to oil pump failure. Among them are contaminants in the oil, improper installation, unbalanced rotating assembly, etc. Since the pump is mounted to the front of the crank, the crank, rods, pistons and the flywheel/clutch assembly must be precisely balanced. If the assembly is even slightly out of balance, the oil pump gear is going to take a serious beating. A ProDrive billet oil pump gear is much stronger than a stock gear and will withstand high RPM vibration much better than a stock unit.
A ProDrive Oil Pump Gear is truly cost effective if you want to protect the investment you’ve made in your engine.
Oil Pump Gear FAQs
Q. Why do I want to change my oil pump gear to a ProDrive unit?
A. An unfortunately common side effect of running high horsepower engines that utilize certain OEM components is that you soon find the limitations of those components. Of course, this usually happens at the most unopportune moment, when you need the engine to perform at its best.
One component that has become an increasing problem as horsepower has increased is the OEM oil pump. For some reason, OEM oil pump failure is especially common in Honda Prelude motors but also happens in B16 and B18 motors.
The stock oil pump is made from sintered metal. This is a process where a very fine powdered metal is placed in a mold and and pressed into shape to bind the material together.
ProDrive Oil Pumps are built from a stress proof billet material that has been proven to handle the extreme loads common in high horsepower motors.
If you want to make it across the finish line first, replacing the weak points in your engine with durable ProDrive components is cheap insurance against component failure.
Q. What else can I do to insure the longevity of my oil pump?
A. First, ProDrive Oil Pump Gear user and engine builder Jeremy Lookofsky, recommends the use of a brand new oil pump case when you install the ProDrive gear. A new case will eliminate any out-of-roundness possibly caused by the OEM oil pump gear. A new case will provide good, cheap peace of mind.
Second, if you're building a stroked race motor, Jeremy recommends having all the bottom end parts balanced. A properly balanced bottom end will help to eliminate harmonics, the number one cause of broken oil pump gears.
Finally, make sure all of the screws on the back side of the oil pump case are tight. Use a little red Loctite(R) on the screws when assembling the case. Even a few thousanths of an inch of movement can cause abnormal oil pump wear and securing the screws will prevent them from backing out under vibration which will keep the gear from moving around.
Brand new still in the plastic, $200 Shipped
Used GTECH Pro $Make Offer
http://www.gtechpro.com/gtechpro.html
G-TECH/Pro is an electronic Performance Meter for automobiles. It's designed to make a professional test driver out of anybody. All you have to do is plug it in a cigarette lighter, mount it to the windshield and start accelerating. G-TECH/Pro does the rest automatically and displays the results. It's a great way to get performance and safety information about you car.
Since we won the "Best New Accessory Product" award at the SEMA (Specialty Equipment Market Association) show in Las Vegas for the original G-TECH we haven't stopped research and development. The result is the all new G-TECH/Pro model.
We are very proud of the all new G-TECH/Pro. The responses to the Pro have been phenomenal. Magazines are raving about it. Customers are loving it. New Digital Signal Processing algorithms coupled with Gold Plated Circuitry and a Precision Silicon Accelerometer insure impeccable accuracy.
Old Jul 19, 2004 | 08:59 AM
int3gra's Avatar
Default Re: FS: ProDrive Oil Pump Gear (New), GTECH Pro (Used) .... Dialup Killer (int3gra)
TTT
Old Jul 19, 2004 | 03:33 PM
int3gra's Avatar
Old Jul 20, 2004 | 09:04 AM
int3gra's Avatar
someone take these off my hands.
Old Jul 21, 2004 | 10:45 AM
int3gra's Avatar
up up and away
Old Jul 23, 2004 | 07:11 AM
91civicDXdude's Avatar
[greg]THESE THINGS SELL LIKE HOTCAKES. I SHOULD START SHIPPING PANCAKE SYRUP WITH THEM!![/greg]
lol
Old Jul 23, 2004 | 10:03 AM
int3gra's Avatar
Default Re: (91civicDXdude)
I can add maple syrup for free
Old Jul 24, 2004 | 01:24 PM
int3gra's Avatar
Old Jul 24, 2004 | 01:52 PM
FOrSfEd's Avatar
Default Re: FS: ProDrive Oil Pump Gear (int3gra)
pm'd
Old Aug 5, 2004 | 11:21 PM
int3gra's Avatar
Old Aug 7, 2004 | 07:44 PM
int3gra's Avatar
Old Aug 7, 2004 | 07:56 PM
98SpecR's Avatar
pmed
Old Aug 9, 2004 | 11:12 AM
int3gra's Avatar
up
crxrida
Jul 25, 2013 06:31 PM
VaporTrail
Sep 5, 2006 03:35 PM
int3gra
Aug 9, 2004 12:29 PM
mod5
Mar 10, 2003 10:45 AM
mod5
