**Changing Fuel Pump**
Old Jul 18, 2004 | 09:18 PM
Ragezero76's Avatar
Default **Changing Fuel Pump**
How hard is it to change your fuel pump? i know it is located under the back seat. by the way i have a 1992 hatch dx. wondering if i can use a 89 si fuel pump? and do i have to drop the fuel tank?
Old Jul 18, 2004 | 09:22 PM
Muckman's Avatar
Moderator in Chief
Default Re: **Changing Fuel Pump** (Ragezero76)
Its easy. You need to take the rear seat out and its right there on top of the fuel tank. Im not sure about using the other fuel pump
Old Jul 18, 2004 | 10:05 PM
Mike banX's Avatar
no u take the silver lid off under the back seat, then u un screw all the bolts u see on that lid and its inside there and it slides out
Old Jul 19, 2004 | 09:35 AM
LudeyKrus's Avatar
It's easy; go for it!
Old Jul 19, 2004 | 12:51 PM
integra6650's Avatar
Default Re: (LudeyKrus)
why not get an aftermarket their only a hundred or so
Old Jul 19, 2004 | 12:53 PM
Tyree's Avatar
Default Re: (integra6650)
http://www.c-speedracing.com/h...p.php
Old Jul 19, 2004 | 05:09 PM
numba1's Avatar
it's simple just take your rear seat out, see the silver oval thingy (cover) undo the screws open the cover undo the wireing pull it out take out the fuel pump get the new one follow the directions on how to assemble it slide it in the bracket holder put it back inthe tank hook up the connections and screw in the screws turn on the ignition and hear it HUMMMMMMMMMMMMMIIIIINNNNNNGGGGGGGGGG!!!!!!!!!!!!!! and NOyou can't use the ef's fuel pump straight across swap. but you can use integras 94 and up there all compatible.
90 ef
Dec 2, 2009 05:33 PM
SilverPanda
Oct 3, 2007 01:56 PM
KevronsEG
Jul 6, 2007 02:47 PM
tilt
11
Nov 30, 2002 08:36 PM
SpeedMonkeyRacing
Nov 29, 2002 06:08 AM
