has anyone done a 90-93 teg right hand drive conversion.
hrmm..you should be able to...if I thinking correctly all you have to do is just move the wiring over to the right side..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TimmydaTeg »</TD></TR><TR><TD CLASS="quote">hrmm..you should be able to...if I thinking correctly all you have to do is just move the wiring over to the right side..</TD></TR></TABLE>
If thats ALL you had to do, i bet a lot more people would have done it.
Its not just the interior that would need to be refitted, its also in the engine bay.
Its basically not possible for the average person to even attempt.
The firewall is different. The pedal assembly has to go through on the right side now. The gauge cluster, everything.
Its cheaper to get a mint front clip and weld it on.
Or to get a JDM teg.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmattlee3 »</TD></TR><TR><TD CLASS="quote">i am wondering if i can use my stock dash harness because someone cut the jdm one i got</TD></TR></TABLE>
hey, you're in covington. theres a shop about 20 miles north of you called raceline. they've done a rhd conversion to an eh2. check them out @ http://www.racelinetuning.com get ahold of rick, he's a cool guy... he can help answer questions (its his personal car.)
SPOON_BeIgHtEeNsEe
Feb 26, 2002 11:31 AM
