Horn NOT Honking!! IT REALLY SUCKS
Old Jul 18, 2004 | 06:23 PM
detaude's Avatar
Default Horn NOT Honking!! IT REALLY SUCKS
Okay, I have a 98 LS, and for some reason the horn does not work. I've already checked the fuse, and it was fine. When I press the button, it makes a faint clicking sound, but that's about it.
Please help me guys, It really sucks because people try to run into me all the times and I can't honk my horn at stupid drivers or hot bitches.
Old Jul 18, 2004 | 06:28 PM
Kendall's Avatar
I believe the actual horn maybe shot. The clicking is the horn relay. Try using a horn from a friend, if it works, then you know your problem.
Old Jul 18, 2004 | 07:08 PM
detaude's Avatar
Default Re: (Kendall)
I hope it's just the horn, this way I can just switch it out and not have to screw with the wiring and stuff.
Old Jul 19, 2004 | 12:22 PM
detaude's Avatar
Default Re: (detaude)
Anyone else might know what's wrong???
Old Jul 19, 2004 | 01:55 PM
Tweakmeister's Avatar
Either a bad connection or it's shot >> the clicking suggests it isn't getting enough power
You might want to upgrade to some Hello horns, they are pretty cheap and don't make the roadrunner sound.
Old Jul 19, 2004 | 02:09 PM
MyBigNut's Avatar
Default Re: (Tweakmeister)
I remember after my car was broken into, my horn wasnt working. After checking fuses, I noticed the thing was just unplugged. I also experienced the same clicking sound as you described.
Old Jul 19, 2004 | 02:11 PM
Deluzional's Avatar
Default Re: (MyBigNut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MyBigNut &raquo;</TD></TR><TR><TD CLASS="quote">I noticed the thing was just unplugged. .</TD></TR></TABLE>
Had the same problem, i had a bad connection and it would continually come loose, so i opted for some hella horns
Old Jul 19, 2004 | 02:35 PM
backlash's Avatar
Default Re: Horn NOT Honking!! IT REALLY SUCKS (detaude)
I had that problem when I took my horn out and put it back. It was not working when I put it back, then I checked to see if I bolted it back in all the way and one bolt was missing. After I put the bolt back in it worked.....weird
Old Jul 19, 2004 | 02:48 PM
Default Re: Horn NOT Honking!! IT REALLY SUCKS (backlash)
the horn grounds against the frame, so it has to be bolted down well
zenon8890
10
Nov 16, 2008 04:42 PM
tei344
Nov 9, 2007 05:51 AM
Redemption
Jun 24, 2007 03:18 PM
sinister357
May 24, 2005 10:32 PM
SlyGSR
Apr 9, 2002 06:37 AM
