EAGLE RODS WONT FIT...NEED HELP!!!!!
Old Jul 18, 2004 | 05:50 PM
slammedcoupe's Avatar
Default EAGLE RODS WONT FIT...NEED HELP!!!!!
Just what it says, I bought a set of Eagle H-beam rods and they just wont fit. I pulled the motor and took out the crank, switched the bearings over, put the SRP pistons on and then put the crank back in. Now i put the rods down with pistons attached of course and once i put the rods together and try to spin the crank, it only goes halfway because the rods touch the wall, the very bottom of it.
What shold i do???
Old Jul 18, 2004 | 09:49 PM
boostn420's Avatar
Default Re: EAGLE RODS WONT FIT...NEED HELP!!!!! (slammedcoupe)
Make sure that the parts are right. If they are then you may need to remove material from teh bottom of the sleeves so the rod can clear.
1750cc
Nov 23, 2004 05:21 AM
slammedcoupe
Jul 18, 2004 06:53 PM
slammedcoupe
Jul 18, 2004 05:59 PM
