fs: hasport, skunk2, tires, msd, crx parts and more (chicago)
obd-1 injectors off 94 prelude (290cc) $100. shipped
88-91 crx greddy catback exhaust (2.5" piping)
still in the box paid $550. asking $475.
obd-2 dizzy, under 3k miles $150.
96 gsr alternator w/aem pulley and belt $100.
96 gsr starter $50.
96 gsr (would like to sell as a set)
axles, motor mounts, shift linkage, inter shaft,
every bolt, bushing and shifter. $325.
88-91 crx/civic hasport motor mounts $260.
billet ones, b'series motor swap
clutch net stage 1clutch w/plate,
for b16a1 cable trannys, under 3k
miles on it. paid $380. for it. asking $175.
will work on 90-91 integra b' series trannys
itr usdm header w/gasket $50.
msd 6a box, ss blaster coil,
obd-0 dizzy w/cap and wire $275.
88-91 civic/crx stock muffler $5.
(just muffler, will work on EF'S)
2.5" glasspack 18" long $5.
91 crx si throttle body w/no sensors $5.
91 crx si stock cat $5.
91 crx si stock rotors
(all 4 corners in great shape) $25.
91 crx si stock brake lines (all 4 lines) $15.
91 stock crx si intake box w/filter and tube $15.
92 civic vx stock box w/filter and tube. free w/anything you buy, pick up only
91 crx dx stock steering wheel $5.
97 gsr stock flywheel $15.
96 gsr stock flywheel $15.
obd-2 injectors from a 97 gsr (all 4) $20.
obd-2 injectors from a 96 gsr (all 4) $20.
91 crx si stock header $10.
91 crx si stock springs all 4 $20.
91 crx si stock sturts (all 4 in great shape) $25.
97 gsr stock head studs 1.8L (all 10 studs) $20.
Modified by b16powwer at 10:05 PM 7/28/2004
96 gsr starter $50.
b16powwer
Jul 4, 2004 05:53 PM
