B16 Swap problem
Old Jul 18, 2004 | 01:01 PM
All Day's Avatar
Default B16 Swap problem
I ran a search on this but couldnt find what I was looking for. Closest thing was this: https://honda-tech.com/zerothread?id=768633 . I have the same problem as he does when my engine warms up, the pulsating. I also have a CEL but it doesnt give a code when I go get it checked out. I have a 98 Civic EX. Using the EX Wiring Harness, Boomslang OBD-2B to OBD-2A jumper harness, P2T(99 Si) ECU. I had to extend a few wires to make the EX harness fit (but i knew that had to be done). One sensor is missing. IAC sensor is the one i think (on the back of the intake manifold), but the sensor is the same shape as the sensor that is on the vaccum line to the charcoal canister. switched them out and my rpms when starting the car sat at around 2000 and it still pulsated.. im f'n confused.. help please
Old Jul 18, 2004 | 05:15 PM
All Day's Avatar
Default Re: B16 Swap problem (sincehonda)
please help
Old Jul 19, 2004 | 04:11 AM
All Day's Avatar
need help!!!
Old Jul 19, 2004 | 09:50 AM
tallblondkid's Avatar
just swapped my in this morning and having the exact same problem, if u have found out anything please let me know
Old Jul 19, 2004 | 05:26 PM
Master23's Avatar
Check the ground connection on the thermostat housing and make sure its snug.
gsr96cx
May 19, 2009 08:05 PM
97Ej6mike
Sep 10, 2007 08:19 AM
kgibson16
Jan 24, 2006 04:46 PM
kgibson16
Jan 24, 2006 12:43 PM
hatchpat
Jan 8, 2005 03:36 PM
