reseting ecu?
Old Jul 18, 2004 | 12:12 PM
i20ar's Avatar
Default reseting ecu?
iw as in a forum the other day someone said they reset there ecu after installing their new CAI soooi was wondering how do you do that? and what happens when you do that?
Old Jul 18, 2004 | 01:38 PM
JDM.Accord's Avatar
Default Re: reseting ecu? (14aZnS)
You can pull out the ecu fuse in the fuse box
Old Jul 18, 2004 | 06:58 PM
devilpuppy's Avatar
Default Re: reseting ecu? (JDMAccord2nr)
yea...i always hear about this ecu reseting thing
wat is it all about and what is the purpose of doin it?
Old Jul 18, 2004 | 07:06 PM
Robot Sonic's Avatar
Default Re: reseting ecu? (devilpuppy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilpuppy &raquo;</TD></TR><TR><TD CLASS="quote">yea...i always hear about this ecu reseting thing
wat is it all about and what is the purpose of doin it?</TD></TR></TABLE>
yea, someone once told me that resetting the ECU basically reconfigures all of your driving habits recorded by the car, back to what it was at default...is there any truth in that?
Old Jul 19, 2004 | 05:54 AM
Elvis1977's Avatar
Default Re: reseting ecu? (Robot Sonic)
I think so.
Old Jul 19, 2004 | 06:55 AM
Nick H's Avatar
New User
Default Re: reseting ecu? (Elvis1977)
the ecu has a small learning curve (in auto's the tcu does this as well) where the driving style is considered in the fuel maps and timing maps...it's not a very big change, but there is a small amount...by resetting the ecu, it relearns your current setup by checking all the sensors...when it sees more air from an aftermarket intake, it adjusts the fuel accordingly...it would do the same eventually, but resetting the ecu makes the change instantaneous instead of waiting for the change to happen over a period of time...
Old Jul 19, 2004 | 07:42 AM
Default Re: reseting ecu? (Nick H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H &raquo;</TD></TR><TR><TD CLASS="quote">the ecu has a small learning curve (in auto's the tcu does this as well) where the driving style is considered in the fuel maps and timing maps...it's not a very big change, but there is a small amount...by resetting the ecu, it relearns your current setup by checking all the sensors...when it sees more air from an aftermarket intake, it adjusts the fuel accordingly...it would do the same eventually, but resetting the ecu makes the change instantaneous instead of waiting for the change to happen over a period of time...</TD></TR></TABLE>
you think that if i have an aftermarket fuel pressure regulator, this would make a difference to how the ECU blueprints out the fuel maps and timing curves?
oh, does it do harm to run the pressure regulator at max?
vinuneuro
Jul 25, 2008 11:58 PM
CTR_EK9
Feb 24, 2003 04:14 PM
Rukusmasta2
Feb 17, 2003 03:01 PM
SOHC_MShue
Oct 14, 2002 11:22 AM
