Heres the deal
Ok I bought a Tranny, the guy told me its an Si but unsure about the year.
I have searched & found out that it is infact an Si because of the "beefer" axle shaft inputs, but still unsure about the year.
I have ovisouly a 90Dx Hb, but the tranny has no Flywheel. So should i buy a clutch for my civic & use the old flywheel (jus have it resurfaced)? w/ a new clutch kit for a 90 DX? or should i buy one for a 90 Si?
all dseries flywheels are interchangable except for one year was the bastard year (88 or 89 i dont remember) it has either 1 more or 1 less splines than all the other years. but if you have a 90 flywheel and it has the same number of splines as your tranny then it will work fine! this goes for clutches also!
ok cool, Thanks
Hey is the Si Clutch any stronger than the Dx Clutch?
Oh, Also I curently have a 4speed tranny in the car now. This doesnt change anything right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchback_al »</TD></TR><TR><TD CLASS="quote">all dseries flywheels are interchangable except for one year was the bastard year (88 or 89 i dont remember) it has either 1 more or 1 less splines than all the other years. but if you have a 90 flywheel and it has the same number of splines as your tranny then it will work fine! this goes for clutches also!</TD></TR></TABLE>
that would be the 88...sir
and its + 1 spline
and its + 1 spline
CRXalwysk8
13
May 3, 2005 07:18 AM
kekek-20
11
Jan 4, 2004 01:50 PM
sohcvtec66
Nov 18, 2003 09:49 AM
