arp rod bolts
Old Jul 18, 2004 | 11:33 AM
andera's Avatar
Default arp rod bolts
So,
I'm gonna be getting my JDM B20b soon.... I'm gonna go with a B20Vtec setup, but my quetsion here is.. ... before i put the b20 into the car would it be simple to take the oil pan off and change the rod bolts to arp rod bolts? w/out having to dissassemble everything? can anyone give some input on that? Thanks.
Old Jul 18, 2004 | 01:48 PM
DonF's Avatar
Default Re: arp rod bolts (andera)
No, you must recondition (machine) the rods with the new with the new torque spec., or they will be out-of-round.
Old Jul 18, 2004 | 01:50 PM
andera's Avatar
Default Re: arp rod bolts (DonF)
ah bummer. i'll just keep it at 7500 then hehe.
Old Jul 18, 2004 | 02:15 PM
DonF's Avatar
Yea, the truth hurts, but I would still pull the pan, see if the oil has ever been changed, and remove the #2 rod bearing cap, or all, to check the conition of the bearings, replace if necessary, TQ to factory specs. It's cheaper to check it now, than later. Hope you got a good one.
Old Jul 18, 2004 | 05:01 PM
andera's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Yea, the truth hurts, but I would still pull the pan, see if the oil has ever been changed, and remove the #2 rod bearing cap, or all, to check the conition of the bearings, replace if necessary, TQ to factory specs. It's cheaper to check it now, than later. Hope you got a good one.</TD></TR></TABLE>
me hopes so too, only 21k miles. maybe i should just replace rod bearings anyway? i only want this until next summer so i guess its not TOO big of a deal... always got the b18b in teh garage too. then im gonna get ahold of a B17 crank with the GSR head + JRSC should be good.
how much would it cost (on average) to have someone change the rod bolts? like if i took the block to a shop before installing
Corksil
12
Sep 19, 2012 11:49 AM
88Snatch
Jul 19, 2007 08:18 PM
dustrag
Dec 8, 2004 06:29 PM
M.K.C.
Jan 6, 2004 12:41 PM
willyboyK20
Mar 25, 2003 05:33 AM
