auto engine swas
How you doin. I am planning on swapping a B18A into my civic, but i want to leave it automatic. Is the swap the same as with a 5- speed swap? I already have the motor, ecu, harness, tranny and axles. Do i need a shift linkage or something like that? Any other info on my swap will be greatly appreciated. Thanx.
[Modified by jdmhatch, 8:27 PM 11/24/2001]
[Modified by jdmhatch, 8:28 PM 11/24/2001]
From: gravity rides everything...everything will fall, se GA/ne FL
no. you need to wire in a transmission computer too. i might could help you but mine was obd1 and b18b. and it was a bitch from hell but i did it. it also doesn't bolt right in like the 5 speed swaps...the mounts have to be altered a bit but nothing to terribly hard. yeah it's possible. i put turbo and my auto hybrid runs mid 8's in the 8th and low 13's in the quarter...maybe high 12 with slicks or whatever. if you want to leave it auto then don't listen to bitches telling you to do else what you want. as long as your car is fast then it doesn't matter because i'll **** the **** out of most 5-speeds that **** with me anyway...**** 6-speeds...beat a m-coupe, formula's, 5.0's, vettes, tt 7's, vr4's, and 300z's. stock motor and drumroll please...6 psi of boost so there. oh yeah, and a **** box for a tranny.
Thanx alot man. I would love to talk to you more about this swap. Drop me an email at mikexr167@aol.com or if you have aol drop me an im. It sounds kind of complicated. Im gonna buy a motor tommorrow so let me know. Thanx.
