h22a swap in my 6th gen accord (big problems)
Old Jul 17, 2004 | 04:01 PM
Subwarrior's Avatar
Default h22a swap in my 6th gen accord (big problems)
I began a h22a swap into my 99 accord. I just dropped 1500 bucks more into the auto to manual conversion. I am having problems left and right. I can't get any of the motor mounts to line up properly, the power steering pump line doesnt reach, the throttle cable is way too long, these are just a few of my problems. I was tempted to abandon the project but there is already so much time and money invested in it. If anybody has pics of their swap, or advice on any of the above troubles, or anything, I'd greatly appreciate it.
Old Jul 17, 2004 | 05:37 PM
asnboi_512's Avatar
Default Re: h22a swap in my 6th gen accord (Subwarrior)
urs a coupe? or sedan? if a coupe.. trade me i got a 94 coupe lol it'll be easy to swap it and mines already converted to manny
Old Jul 17, 2004 | 06:36 PM
Crono139's Avatar
You have to use a Prelude engine mount for the driver side, I believe.
Old Jul 17, 2004 | 09:48 PM
Subwarrior's Avatar
Default Re: h22a swap in my 6th gen accord (Crono139)
Well the prelude mount doesnt line up with accord bracket, accord mount doesnt line up with h22 bracket. And by the way it is a 4 door lx. I contacted hasport, and they never heard of a 6th gen h22a swap. But I know someone's done it! It just seems like nothing lines up. When I purchased the engine from jdm I was told it was a very simple and common swap. It has been neither nor to this point.
Old Jul 18, 2004 | 04:59 PM
jlv55's Avatar
im doin the same thing man, but with an h23. i HEARD that you are supposed to use the f23 bracket AND motor mount on the driver side. i tried taking the bracket from my f23 and putting it on the h23 block, but it didnt fit. supposedly it fits on the h22 block.
what part of your power steering line didnt reach? the piece going from the firewall to the top of the pump?
and what throttle cable did you use?
u help me, ill help you.
Old Jul 18, 2004 | 06:23 PM
madd's Avatar
dont you use the prelude mount, but you have to grind it down some to get it to work properly?
Old Jul 18, 2004 | 06:43 PM
6thgen_H22accord's Avatar
h22 motor mount bracket wont work, use the f23 bracket and make some kind or plate to attack the second bolt. I have the place racing motor mount but not the bracket.
For your power steering pump problem just remove the bolt holding it to the chassis on the bottom there is a clamp holding it down, remove it and problem solved there.
throttle cable use your accord one. If you need anymore help pm me and ill try to help out
Old Jul 18, 2004 | 11:30 PM
jlv55's Avatar
Default Re: h22a swap in my 6th gen accord (6thgen_H22accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6thgen_H22accord &raquo;</TD></TR><TR><TD CLASS="quote">h22 motor mount bracket wont work, use the f23 bracket and make some kind or plate to attack the second bolt. I have the place racing motor mount but not the bracket.
help out</TD></TR></TABLE>
if your telling him to use the f23 bracket, then he sohuld be able to use the f23 mount also. the bracket is what attaches to the actual block, the only question is:
does the f23 bracket fit the h22 block????
Old Jul 19, 2004 | 03:42 AM
-Bionic-'s Avatar
Former Sponsor
Default Re: h22a swap in my 6th gen accord (klutch44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klutch44 &raquo;</TD></TR><TR><TD CLASS="quote">
does the f23 bracket fit the h22 block???? </TD></TR></TABLE>
Yes it does, and it has been covered before.
Old Jul 19, 2004 | 03:43 AM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crono139 &raquo;</TD></TR><TR><TD CLASS="quote">You have to use a Prelude engine mount for the driver side, I believe.</TD></TR></TABLE>
No...use all of the mounts and brakets from the F23.
Old Jul 19, 2004 | 03:44 AM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Subwarrior &raquo;</TD></TR><TR><TD CLASS="quote">Well the prelude mount doesnt line up with accord bracket, accord mount doesnt line up with h22 bracket. </TD></TR></TABLE>
Swap the h22 bracket with the F23 bracket, and use the F23 mount. This has been covered before. Search.
Old Jul 19, 2004 | 03:46 AM
-Bionic-'s Avatar
Former Sponsor
Hope it helps and have a good day.
Goodbye.
Old Jul 19, 2004 | 09:34 AM
jlv55's Avatar
Default Re: (-Bionic-)
yea, youve said it before, but you have not proven it with a picture. i really dont believe you...
Old Jul 19, 2004 | 10:39 AM
Subwarrior's Avatar
Default Re: (klutch44)
I appreciate the advice. Let's see if I can sum it all up in better detail. f23 bracket and mount for front and rear, well, they all need to be f23 brackets and mounts, with the driver side bracket being modified. And what do you mean to take bolt out of chassis for steering pump, you mean remove pwr steering?
Old Jul 19, 2004 | 02:17 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: (Subwarrior)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Subwarrior &raquo;</TD></TR><TR><TD CLASS="quote">I appreciate the advice. Let's see if I can sum it all up in better detail. f23 bracket and mount for front and rear, well, they all need to be f23 brackets and mounts, with the driver side bracket being modified. </TD></TR></TABLE>
No modification...simply replace h22 engine bracket with F23 engine bracket .
Old Jul 19, 2004 | 02:21 PM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klutch44 &raquo;</TD></TR><TR><TD CLASS="quote">yea, youve said it before, but you have not proven it with a picture. i really dont believe you...</TD></TR></TABLE>
so? I don't care if you don't believe me... that's your problem. Remember, I'm driving around in a 6th gen H22 accord, and you are not. LOL
Old Jul 19, 2004 | 02:26 PM
jlv55's Avatar
yea, but atleast when im done my swap i am going to help others out with showing them pictures.
Old Jul 19, 2004 | 02:29 PM
-Bionic-'s Avatar
Former Sponsor
Yeah, like I'm not helping out.
Tell me...from a picture can you tell whether an engine mount is from a H22, F23, or custom made? I'm giving specific details on how to solve that problem with the engine mount. Some people are ungreatful.
Old Jul 19, 2004 | 02:33 PM
-Bionic-'s Avatar
Former Sponsor
Second of all, you are trying to install a H23, correct?
Hint, "h22a swap in my 6th gen accord (big problems)"
Old Jul 19, 2004 | 03:42 PM
jlv55's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Bionic- &raquo;</TD></TR><TR><TD CLASS="quote">Second of all, you are trying to install a H23, correct?
Hint, "h22a swap in my 6th gen accord (big problems)"</TD></TR></TABLE>
which is why i am trying to help him out. stop arguing and go take a picture for him.
Old Jul 19, 2004 | 03:50 PM
yun_cheezie's Avatar
i can try and send you pix of my swap...(see sig) although my car is a '00 coupe lx 5spd, i was able to use "ALL OF MY FACORTY MOUNTS." even the drivers (one hole lined up perfect on the bracket, and the other hole i drilled out...then put long 17mm bolt and nut to secure it). i've had problems posting pix on threads before but, if someone can help me out i'll post as many as you need. as far as the power steering pump issue, i used my accord bottom line (that goes to the rack) and has a pro-line hose shop splice in a 93+ lude upper line that goes to the pump.
Old Jul 19, 2004 | 03:59 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: (yun_cheezie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yun_cheezie &raquo;</TD></TR><TR><TD CLASS="quote">even the drivers (one hole lined up perfect on the bracket, and the other hole i drilled out...then put long 17mm bolt and nut to secure it).</TD></TR></TABLE>
That technique works, since I used to drive around like that, but then I was told by my shop to use the F23 bracket. I tried and it worked.
This topic has been covered before. I know since I created one about 7 months ago. --&gt; https://honda-tech.com/zerothread?id=689185
As you can see...klutch44 is obsessed with pictures and he has been sweating me for a long time.
Old Jul 19, 2004 | 04:41 PM
SuperSlow's Avatar
Go on then... Show them a pic of your engine bay. I know you are shy because it is not al gay and pretty like them show cars, but maybe they'll appreciate your free info. OR let them go and drive around with cracked mounts for a while scratching their heads and wondering what the problem is.
Just gimme a call when you wanna put in them new axles.
Old Jul 19, 2004 | 04:57 PM
jlv55's Avatar
Default Re: (SuperSlow)
i doubt bionic even has a car.
Old Jul 19, 2004 | 05:56 PM
-Bionic-'s Avatar
Former Sponsor
Hehe.
for the good humor in klutch444. BTW did you get the nuts for the clutch?
