Valve Cover
What is the best stuff to clean a valve cover and get it ready for paint? I have a SOCH (d16y8) and its in some nasty shape dirt wise. What all do I have to do to prep the valve cover? Once I take off the valve cover what do I need to do while re installing the valve cover? Do I need to get a new gasket? What is the best paint to use while painting a valve cover? I have a VSM (silver) 00 civic and im thinking ither RED or GUNMETAL paint.
If you want to repaint it get some sand paper and sand it down. You can reuse the gasket if your are careful when removing the cover off. Just add some hondabond to it.
So sand it and thats all? How many coats, what color do you all think will look better on VSM and what brand paint etc. What is hondabond?
i just did the valve cover on my integra, got to autozone or advance auto and pic up some aircraft remover, high temp ceramic engine paint, rubber gloves, and a paintbrush. The aircraft remover does an awesome job to strip to finish off the valve cover. After that, a quick sanding and your ready for paint. Smear vasoline onto the parts that you dont want the paint to stick (the lettering).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMC Integra »</TD></TR><TR><TD CLASS="quote">i just did the valve cover on my integra, got to autozone or advance auto and pic up some aircraft remover, high temp ceramic engine paint, rubber gloves, and a paintbrush. The aircraft remover does an awesome job to strip to finish off the valve cover. After that, a quick sanding and your ready for paint. Smear vasoline onto the parts that you dont want the paint to stick (the lettering).</TD></TR></TABLE>
aircraft remover is awesome!!!
If its just dirty and not chipped, I would just use
soapy watter to clean it.
I cant remember if the y8 is painted or not?
If it is, and it already has the crinkle paint on it,
and its not all chipping off, then I would just get normal
spraypaint. Im not sold on this hi temp stuff, it all looks
like crap for me if it gets too hot.
I dont think the y8 is painted though, so you will have to
get the wrinkle paint. I forget what everyone uses. Try
to search for "valve cover", I think its like kvt or hvt, something
with three letters and has a v in it. heh......good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elwood »</TD></TR><TR><TD CLASS="quote">If its just dirty and not chipped, I would just use
soapy watter to clean it. </TD></TR></TABLE>
I used Simply Green (Automotive) from Pep Boys and it works great.
How do you get the Honda or VTEC or whatever is imprinted into the valve cover to be another color. I would hate to sit there tracing the letters out so I won't get any paint on the letters.
I was thinking on placing some Vaseline or some sort of gel over the letters and spary over it, then, wipe off. Do you think this would work?
Let's say spraying the cover a certain cover and leaving the letters the valve cover's color or paint it another color (like white).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">
I was thinking on placing some Vaseline or some sort of gel over the letters and spary over it, then, wipe off. Do you think this would work? </TD></TR></TABLE>
A lot of people use vasaline.
Since the Y8 valve cover is NOT painted, do you still have to sand it down or whatever? Or do you just clean it really well and then paint it? I've been contemplating about painting mine, too.
EDIT--N/m, found a good DIY thread. https://honda-tech.com/zerothread?id=782937
For the painting reason or for other reasons?
</TD></TR></TABLE>For the painting reason or for other reasons?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel »</TD></TR><TR><TD CLASS="quote">Since the Y8 valve cover is NOT painted, do you still have to sand it down or whatever? Or do you just clean it really well and then paint it? I've been contemplating about painting mine, too.</TD></TR></TABLE>
I would give it a good scuffing. They have red and gray scotchbrite
pads for this.
Red= If using a base, like primer.
Gray=If you are just painting.
Sand paper takes things with it, like paint, the scotchbrite will
just ruff up the surface you are painting. I use it at work, and
I love the stuff.
For your unpainted y8 cover, I would just use some gray scotchbrite,
then celan it up, then paint.
For the painting reason or for other reasons?</TD></TR></TABLE>
heh.......well I personally dont use it for anything, but that made
me laugh.
pads for this.
I love the stuff.
me laugh.
me laugh.
Well yeah, but there's some freaks on H-T who love to fool around. I just wanted to know if the this is an ok way to not get paint on letters and what not.
me laugh.
</TD></TR></TABLE>Well yeah, but there's some freaks on H-T who love to fool around. I just wanted to know if the this is an ok way to not get paint on letters and what not.
I want mine to look just like this. Anyone know whos valve cover this is and what I do to make it look like this?
The black one is what i want.
http://www.cardomain.com/memberpage/619579/3
Clean it off really well, sand if you'd like. Use chapstick or vaseline on the lettering and mask off any other areas you want to keep unpainted. Use a can of black Wrinkle Paint (Krylon/VHT) and follow the directions.
