my clutch pedal.. weird.
Old Jul 17, 2004 | 02:41 PM
pane93civhb's Avatar
Default my clutch pedal.. weird.
I was driving last night... mind u my motors mounts drivers side exploded and rear mount completly disconnected.. tranny mount looks fine.. newaze.... i was going to fast hit a bump and all of a sudden my clutch has slack for about half of the pedal hoping its nothing serious... what do u guys... think im like the bad luck king i will take any suggestions on this... please help.. civic gods...
Old Jul 17, 2004 | 03:50 PM
Crank's Avatar
Default Re: my clutch pedal.. weird. (pane93civhb)
check your clutch cable, and also check your fluids
Old Jul 17, 2004 | 03:57 PM
u think so like i said it was a sudden swtich after i hit a bump horsebeating my car with broken mounts imin **** TY anyone else..
do u think it may have jerked the cable if i had it depressed at the time..
Old Jul 17, 2004 | 04:03 PM
dogfood's Avatar
Default Re: (pane93civhb)
You have a hydro clutch?, and yes I know that 92 and up have hydro clutches but some people have the cable conversion.Maybe you stretched the hose that connects the two steel lines, maybe that has something to do with it, or possibly bent one of the steel lines.
Old Jul 17, 2004 | 04:23 PM
chad's Avatar
Moderator
Default Re: my clutch pedal.. weird. (Crank)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crank &raquo;</TD></TR><TR><TD CLASS="quote">check your clutch cable, and also check your fluids</TD></TR></TABLE>
no cable clutch on 93 unless he did the conversion....
your slave cylinder probably contacted the fan and didn't let the push rod completely dissenguage....
Old Jul 31, 2004 | 02:43 PM
o yea meet to tell u chad that ur the coolest im sure u were right on with that answer... cuz u probably caught the part that my radiator fell down and that i had a huge *** ls radiator in my hatch thanks alot dude.
1SIKEF8B20VTEC
Oct 5, 2005 04:44 PM
InJ3cted
May 24, 2005 02:16 PM
White93Civic
Feb 24, 2005 08:11 PM
.nate
Sep 12, 2002 12:47 PM
