B16 Fuel rail on a skun2 mani. injectors don't fit. why?
Old Jul 17, 2004 | 09:44 AM
kaj's Avatar
kaj
Default B16 Fuel rail on a skun2 mani. injectors don't fit. why?
the rail is the square one. not sure what year B16 it's from. i tried to use the spacers (the brown plastic ones that go between the rail and mani) from a GS-R..
after bolting up the rail and spacers, i notice the injectors aren't tight. do i need different spacers?
Old Jul 17, 2004 | 11:42 AM
accorse07's Avatar
Default Re: B16 Fuel rail on a skun2 mani. injectors don't fit. why? (kaj)
use gsr rail
Old Jul 17, 2004 | 03:16 PM
zCivic's Avatar
Default Re: B16 Fuel rail on a skun2 mani. injectors don't fit. why? (accorse07)
I used DSM injectors and couldn't use any of the insulators (spacers) never used the stocks but there about the same length so would run into the same problems. I just had to remove the studs and use bolts with washers.
Modified by zCivic at 8:09 PM 7/17/2004
Old Jul 17, 2004 | 04:11 PM
kaj's Avatar
kaj
Default Re: B16 Fuel rail on a skun2 mani. injectors don't fit. why? (zCivic)
i have a ghetto washer setup now.. don't wanna have them flying off everywhere if i ever pull the rail.
so a GS-R fuel rail will work???
Old Jul 17, 2004 | 04:43 PM
-Justin-'s Avatar
im having the same problem with an aebs manifold. I thought about just using a small washer inbetween the injector and rail to take up the space
Old Jul 18, 2004 | 10:33 AM
Rod.'s Avatar
Default Re: B16 Fuel rail on a skun2 mani. injectors don't fit. why? (-Justin-)
i just used a washer on each stud for my skunk2 manifold(b16)
-[uSa]-Defcon_07
Jul 12, 2007 11:13 AM
crx.com
Jan 4, 2006 06:36 PM
zCivic
Feb 24, 2004 01:24 PM
Charlie Moua
Oct 28, 2003 06:41 AM
Sideshow9090
Sep 1, 2002 10:28 PM
