Anyone around that can tell me what weight trans oil I need for my crx
Old Jul 17, 2004 | 08:16 AM
jester's Avatar
Default Anyone around that can tell me what weight trans oil I need for my crx
its a 1988 dx crx stock 1.5l d15b2- I called the auto parts store and they said to see owners manual. Well Im on vaction and didnt know I would be needing it so its 8 hrs away. Kinda need the info quick since I am working on it now
Old Jul 17, 2004 | 08:20 AM
jester's Avatar
Default Re: Anyone around that can tell me what weight trans oil I need for my crx (jester)
I checked the web I am showing regular 10w30 engine oil .. is that correct.. it seems odd
Old Jul 17, 2004 | 08:22 AM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jester &raquo;</TD></TR><TR><TD CLASS="quote">I checked the web I am showing regular 10w30 engine oil .. is that correct.. it seems odd</TD></TR></TABLE>
Yeah its 10w30 but stay with me here, in the old Honda manual it says its perfectly fine to use 10w30, now it you read the new manuals it says use there special trans oil, but you can use 10w30 but it can cause damage in the long run. So is Honda telling the truth or do they just want you to buy there products.
Old Jul 17, 2004 | 08:23 AM
blah13's Avatar
Honda MTF, get it at your dealership. Or 10w-30 motor oil works as well, I prefer mtf since its designed specifically for our trannies.
Old Jul 17, 2004 | 08:25 AM
blah13's Avatar
Default Re: Anyone around that can tell me what weight trans oil I need for my crx (blah13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah its 10w30 but stay with me here, in the old Honda manual it says its perfectly fine to use 10w30, now it you read the new manuals it says use there special trans oil, but you can use 10w30 but it can cause damage in the long run. So is Honda telling the truth or do they just want you to buy there products.</TD></TR></TABLE>
Its probably just bad for the new trannies, differetn materials/clearances etc. For ours I'm sure 10w would be fine. MTF just superseds 10w.
Old Jul 17, 2004 | 08:36 AM
manson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blah13 &raquo;</TD></TR><TR><TD CLASS="quote">Honda MTF, get it at your dealership. Or 10w-30 motor oil works as well, I prefer mtf since its designed specifically for our trannies.</TD></TR></TABLE>
yup. thats what i run.
Old Jul 17, 2004 | 08:39 AM
jester's Avatar
Default Re: Anyone around that can tell me what weight trans oil I need for my crx (manson)
Thanks for the fast response. Its the same old transmission, its just I had to change out my clutch and we had a lot leak out. The car has 210,xxx miles on it so I hope I dont have the same engine/car by the time it wears out
Old Jul 17, 2004 | 08:58 AM
Default Re: Anyone around that can tell me what weight trans oil I need for my crx (Manuel)
Try this stuff, its about 5 bucks at autozone and people swear that it works great.
Old Jul 17, 2004 | 09:41 AM
alexdog69's Avatar
I tried various fluids (including MTF and Mobil-1 15w50) in my D-series transmission...
this was by far the best .. some people like the "GM Synchromesh Friction Modified" version...
i think that they are both available under a regular brand name , as "Synchromesh" [regular] and "SynTorq" (sp?) [friction modified]
Old Jul 17, 2004 | 11:13 AM
jester's Avatar
Default Re: Anyone around that can tell me what weight trans oil I need for my crx (alexdog69)
thanks all for the help, got the clutch in and it works great-- thanks again
Old Jul 17, 2004 | 05:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexdog69 &raquo;</TD></TR><TR><TD CLASS="quote">I tried various fluids (including MTF and Mobil-1 15w50) in my D-series transmission...
This stuff is about 10 dollars a quart, the pennzoil is suppose to be the same thing and cost about 5 dollars.
Old Jul 17, 2004 | 06:34 PM
jdl3000's Avatar
I put any 10-30 for engine oil
for my transmission oil I go to Honda dealer or parts shop(cost me $4 per qt in CA).
I have a civic hatch dx with a d15 stock engine with manual tranny. on transmision oil I put 2qts or 1.9qts to be specific . for my engine oil I put 3-4 qt
popthatclutch13
Transmission & Drivetrain
Aug 22, 2018 09:24 PM
Alex_C
33
Oct 31, 2008 11:04 AM
thiscivicuser
17
Mar 3, 2008 08:45 PM
kadidle
Jan 5, 2007 04:41 PM
