Accord 1990 Check Engine and Cruise Control does not work
Old Jul 16, 2004 | 09:22 PM
rifath's Avatar
Default Accord 1990 Check Engine and Cruise Control does not work
I dont get the Check Engine and Cruise Control lights when i turn on the ignition, before strating the car. The main cruise switch comes up but when i press the SET i dont get the light on the dase and does not seem to be working. I checked both ECU fuse and cruise control fuse and seems to be ok. i even changed the main relay last month. Does anyone have any clue. could it be the cruise control relay, if thats the case can some some tell me where is the cruise control relay located?
Really appriciate your help!
Old Jul 17, 2004 | 10:22 AM
kazuya's Avatar
if your speedo is also not working than its probably your speed sensor(i think that what its called).
Old Jul 17, 2004 | 04:26 PM
rifath's Avatar
Default Re: (kazuya)
my speedo is working well.
my concern is that when i turn on my ignition before starting the car the check engine and cruise control light does not appear on the dash.
woody7121
May 12, 2015 04:03 PM
ej#1
Mar 17, 2008 03:54 PM
mormonboy
Sep 7, 2007 10:24 PM
Elvis1977
Jan 13, 2004 10:52 AM
GapxGuy
Nov 20, 2001 01:00 PM
