what brand should i use for crank pulleys?
Old Nov 23, 2001 | 08:42 PM
EliteIntegra's Avatar
Default what brand should i use for crank pulleys? (why is everyone saying its a bad idea and leave it stock
98 GS integra.... changing my crank pulleys but deciding what brand to use... any suggestions from your own cars?
[Modified by EliteIntegra, 3:57 AM 11/26/2001]
Old Nov 24, 2001 | 03:38 PM
Rhetoric's Avatar
Default Re: what brand should i use for crank pulleys? (EliteIntegra)
Im using an Unorthodox crank pulley, there are also Jdm Ctr crank pulley which only utilize the alternator.
Old Nov 24, 2001 | 07:12 PM
zojirushi's Avatar
Default Re: what brand should i use for crank pulleys? (G S R)
I've been told just to stay with the stock. Otherwise i would have gone with Unorthodox racing.
Old Nov 25, 2001 | 07:23 AM
BoM's Avatar
BoM
Default Re: what brand should i use for crank pulleys? (zojirushi)
Stock /
change your other pullies, power steering and alternator
[Modified by BoM, 11:23 AM 11/25/2001]
Old Nov 25, 2001 | 02:29 PM
bigTom's Avatar
Default Re: what brand should i use for crank pulleys? (BoM)
im using an unorthodox crank pulley but unless u need those few extra ponies... id just leave it stock... and change ur other pulleys...
Old Nov 25, 2001 | 03:01 PM
jteasy's Avatar
New User
Default Re: what brand should i use for crank pulleys? (ek9t)
does it cause damage to the timing belt if you change the crank pulley? Will it bend or become mishappen under stress. My question is why not change it.
bow tie
Oct 17, 2008 01:18 PM
tonylphie
Sep 28, 2004 08:38 PM
fe519
Feb 16, 2003 03:41 PM
