help- new integra is hiding a fuse from me
Ok- so i am pulling out the 94' model kenwood cd player, when the yellow wire (we should all know what the yellow wires, if not you can't help anyway!) comes out of the the kenwood plug and taps the headunit.
*pop* goes a fuse. i know it is a fuse because the clock also took a ****. I have pulled every flippin fuse in the panel and......none are blown. I am about to go nuts figuring out where this thing is, so.............
if you have any feed back, maybe something i am overlooking that would be great!
THANKS
THANKS
check the backup fuse under the hoood....mine did the same thing...searched and searched and nothing...then got nosey and pulled the back up fuse and yup thats what it was. good luck
allmotorej8
Apr 1, 2004 07:06 PM
....:::::runs outside!
