stock b20 vtec..what is the most hp anobody has gotten
Old Jul 16, 2004 | 02:02 PM
Outkastb18's Avatar
Default stock b20 vtec..what is the most hp anobody has gotten
i jus want to no how much u can get out of it because i have a friend with a b20z and b16 head on top of it, fuel is at 40 at idle and a type r manifold,gsr cams,flywheel,intake,arp head bolts,apex n1,cheap 4-1 headers,p28 chipped. it was put together in his garage and has not been tuned yet,but went on the dyno once and put out 193hp which is good but can u emagine cam gears then some tunning.
please tell me wat u think,and wat is your setup soo i can tell him
Old Jul 16, 2004 | 02:11 PM
Tbone's Avatar
Default Re: stock b20 vtec..what is the most hp anobody has gotten (Outkastb18)
Thats good for that setup.. usually they put down 150-175 with that seup.. at least around here
Old Jul 16, 2004 | 02:21 PM
Outkastb18's Avatar
Default Re: stock b20 vtec..what is the most hp anobody has gotten (Tbone)
he is in a dx coupe full interior and was on falken zenies which is not great for the track really also shifting at 8 with gsr tranny did 13.8....i know he can do better because he was not use to the motor yet plus the traction problem the zzz gives off which is a wonderful thing when u coming frome b16 gap spec
he hp was 193
tq was 139-140
Old Jul 16, 2004 | 05:25 PM
X2BOARD's Avatar
13.8 with that much power ? hehehe...j/p
What program is on the p28 ? custom or a 'name brand' ?
Old Jul 16, 2004 | 05:46 PM
chad's Avatar
Moderator
b20z bottomend.....
b16 STOCK head
toda b's
toda header
chipped p28
aem itr intake manifold
ITR intake manifold
spoon tbody
pistons notched for valves....
187 and 143 on a dynapac dyno....
Old Jul 18, 2004 | 10:49 PM
sumo's Avatar
b20
Old Jul 18, 2004 | 11:53 PM
2000ekhatch's Avatar
Default Re: (sumo)
185hp 135tq w/o management
Old Jul 19, 2004 | 06:40 AM
irev210's Avatar
Default Re: (2000ekhatch)
2000 JDM B20B bottom end
1993 JDM B16 top end
stock block with notched pistons
stock head with ITR cams/intake manafold/throttle body
ADJ FPR
AEM Cold Air intake
Custom 2.25" exhaust w/ cat
stock OBD-1 PR3 ECU
DynoJet Dyno at ~90 degrees
My next build is going to be a B18B block with P30 pistons with same head setup just to compare #'s
#'s really dont mean much. Air temp, humidity, elevation, what type of dyno, what type of correction factor etc etc.
Used for nothing more then "reference point"
Old Jul 19, 2004 | 06:51 AM
nos51's Avatar
nice set-up and #s who built it?
Old Jul 19, 2004 | 06:33 PM
irev210's Avatar
Default Re: (nos51)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nos51 &raquo;</TD></TR><TR><TD CLASS="quote">nice set-up and #s who built it?</TD></TR></TABLE>
I did with importJDM as a sponsor
We are doing the B18B next year with the P30's to compare #'s
Old Jul 19, 2004 | 06:38 PM
whiteNtegra's Avatar
Default Re: (irev210)
wow seeing all of these makes me hopefull for my b20vtec
Old Jul 25, 2004 | 06:51 PM
b20bvtec'd's Avatar
My stock b20vtec dyno'd 158hp 120ftlbs
stock b16a head, gsr cams, usdm itr header, stock exhaust, and stock itr airbox
Old Jul 26, 2004 | 06:38 AM
X2BOARD's Avatar
ooh... can't wait to dyno my shift... good #'s there for the stock block !
chrisfromsrq
Jul 13, 2009 12:54 PM
fastcars
Mar 2, 2004 04:48 PM
OEMJDM
Oct 5, 2002 07:29 AM
johnny hatchback
Apr 13, 2002 02:10 PM
