obd1 engine wiring harness into a obd0...
Old Jul 16, 2004 | 01:14 PM
cccya's Avatar
Default obd1 engine wiring harness into a obd0...
is it easier to use a 92-95 si wiring harness, into a 88 crx, when doing the vtec swap, or just change the crx wiring harness.
doing a obd1 sohc vtec swap into a 88 crx..
did a search, and could find what i was looking for.
thanks
Old Jul 16, 2004 | 01:15 PM
Rywire's Avatar
Default Re: obd1 engine wiring harness into a obd0... (cccya)
Always use the harness that came with the car. Ryan
Old Jul 17, 2004 | 05:27 AM
cccya's Avatar
Default Re: obd1 engine wiring harness into a obd0... (droppedcrxsi)
anyone ever used the OBD 1 wiring harness before, in this swap??
Old Jul 17, 2004 | 06:02 AM
CRXBart's Avatar
I just did the swap about a week and a half ago. This IS the way to do it: http://www.knology.net/~jediklc/obd0toobd1swap.htm Some colors might not match up, and you don't need the PSP SW wire, other than that use it as bible. Good luck, and take your time on making the jumper harness, make sure you solder all conections.
Old Jul 17, 2004 | 09:45 AM
cccya's Avatar
Default Re: obd1 engine wiring harness into a obd0... (CRXBart)
thanks that a link i had not found yet.
Old Jul 17, 2004 | 11:21 AM
CRXBart's Avatar
and it is the only link you need good luck and if you have any questions hit me up while it is still fresh in my head.
NINETY2CIVIC
Oct 24, 2007 02:58 PM
MidShipCivic
28
Sep 19, 2007 10:01 PM
birdricer
19
Apr 22, 2007 06:34 PM
Ryan562
Jan 17, 2007 05:31 PM
91hatch_on17's
Sep 2, 2003 08:27 PM
