Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Latest on World Challenge at Sears Point July 2004 (this weekend)
Old Jul 16, 2004 | 10:23 AM
HapaHaole's Avatar
Default Latest on World Challenge at Sears Point July 2004 (this weekend)
So I heard that Jonathan Meris had an engine fire and may not continue racing this weekend. That is unfortunate. I would think that he would have a spare motor/harnesses, or whatever to make sure that he runs this weekend for sure.
I think WC is running two events this weekend too!
Anyone go to the practice days and have pix and more news?
Old Jul 16, 2004 | 11:19 AM
Greyout's Avatar
Default Re: Latest on World Challenge at Sears Point July 2004 (SBE)
If only it weren't for those silly 'appearance' rules, cars with minor fire damage could continue...
Old Jul 19, 2004 | 08:59 AM
vtecjj's Avatar
Well I had to retire early this past weekend because of a car fire (not engine fire). Thanks to the COMPTECH race exhaust that broke (for a 2nd time), the muffler packing first started stringing out of the down tube, then the remaining fiberglass packing forced it's way to the end of the muffler can and caused the down tube to break (busted all allen screws around the can except for the two top allen screws). Consequently, the down tube was held by only the top two allen fasteners and the down tube bent up and pointed towards the fuel tank. The exhaust eventually burned my wiring and fuel lines and the fire made it's way inside the cockpit.
After exiting turn seven my engine died (probably from not getting fuel since my fuel pump wiring was burned-which killed my fuel pump) and as I coasted thru turns 8 and 8A I saw flames next to me! It turned out that my left shoulder harness was on fire which spread on to my seat. At this point, I was trying to three things: 1) slow the car down enough to pull off to the side of the track, 2) release my 5pt. harness to prepare to jump out, and 3) trying to undo the window net. when the car slowed to about 10mph I jumped out and rolled onto the ground, then I realized that the car was still rolling and I had to stop it from rolling onto the K-wall on the side of the track. I finally stopped the car by holding onto the b-pillar while dragging my feet. To make matters worse, I pulled the pin for the fire system then pulled to the t-handle only to find that the t-handle broke-off the attachment rod that was connected to the pull cable to activate the fire bottle!!
After that whole ordeal, I was left with a burnt nose and right eyebrow, and burnt off eyelashes on my right eye. As for the car: a need fuel tank is needed, new seat and harness,fuel lines, brake lines, t-body/tps sensor/ and paint.
all because of another defective COMPTECH race muffler which they did not want to replace.
jmeris
Old Jul 19, 2004 | 09:04 AM
Andrie Hartanto's Avatar
Jonathan,
that really suck. Glad to hear you escaped with only minor injuries.
I would like to know more info on the comptech header that broke. Where did it break? Did you mount it with just the bolts on the head, or did you use the lower bracket mounts onto the bottom block as well?
Old Jul 19, 2004 | 09:24 AM
Hunter's Avatar
Default Re: (Andrie)
wow, that sucks! sorry to hear that!
that's quite a sequence of events
Old Jul 19, 2004 | 10:18 AM
vtecjj's Avatar
hey Andrie,
It wasn't my header, it was the race muffler that broke (twice). The race muffler basically comes off the header and is about 3-4ft. long with a motorcycle muffler/can at the end of the tube. A turn down exhaust tube is connected at the end of the muffler/can by allen screws, which is what broke and redirected my exhaust gases towards my gas tank.
Old Jul 19, 2004 | 10:27 AM
Default Re: (vtecjj)
Jonathan,
sorry I brain faded. I don't know why I think it was the header.
Anyway, sorry it happened. hopefully you can try again at Laguna.
Old Jul 22, 2004 | 03:38 PM
futomame's Avatar
Default Re: Latest on World Challenge at Sears Point July 2004 (vtecjj)
I've been told if you wear your visor down, you won't burn your nose, eyebrows and eye lashes!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecjj &raquo;</TD></TR><TR><TD CLASS="quote">After that whole ordeal, I was left with a burnt nose and right eyebrow, and burnt off eyelashes on my right eye.</TD></TR></TABLE>
Old Jul 22, 2004 | 03:45 PM
vtecjj's Avatar
Default Re: Latest on World Challenge at Sears Point July 2004 (futomame)
Yeah, well my friend, I've been told that COMPTECH products were well built and reliable, but it's evident that their products aren't...at least in my case.
maybe I should forget about Civics, Integras, RSX's, & TSX's and just get a S2k?.
Old Jul 22, 2004 | 07:14 PM
ITRbroham's Avatar
shit post warrior
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecjj &raquo;</TD></TR><TR><TD CLASS="quote">maybe I should forget about Civics, Integras, RSX's, & TSX's and just get a S2k?. </TD></TR></TABLE>
[chants]DO IT.....DO IT.....DO IT......DO IT![/chants]
Old Jul 23, 2004 | 05:08 AM
futomame's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecjj &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, well my friend, I've been told that COMPTECH products were well built and reliable </TD></TR></TABLE>
You should have known better.
Nah.. make the complete switch.. go Nissan V-Spec w/ a QR motor. Maybe you'll get on the track sometime in 2008!
Old Jul 23, 2004 | 05:31 AM
vtecjj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by futomame &raquo;</TD></TR><TR><TD CLASS="quote">
Nah.. make the complete switch.. go Nissan V-Spec w/ a QR motor. Maybe you'll get on the track sometime in 2008! </TD></TR></TABLE>
good idea...except maybe I'll go Spec-V and use the QR block and find a way to use the SR-20VE head with the Altima tranny to get the best of 3 worlds (just kidding for all your Nissan nerds)... But if I pioneer this monster it might take me to 2010, by then, the car won't be legal in World Challenge....then it can just sit in my garage NEXT to my previous race car.
Old Jul 23, 2004 | 05:42 AM
futomame's Avatar
I don't know about <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecjj &raquo;</TD></TR><TR><TD CLASS="quote"> ..pioneer </TD></TR></TABLE>... I've heard there is another <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecjj &raquo;</TD></TR><TR><TD CLASS="quote"> ..Nissan nerd </TD></TR></TABLE> who is doing something like this or close to it. He's almost done and will be on the track sometime in '09.
Old Jul 25, 2004 | 07:53 PM
evil vapor's Avatar
just get the s2000 and call it day, look out for websites that charge money tho!
Old Jul 26, 2004 | 05:45 AM
Footwork's Avatar
JM is fast, but can he beat billy auberlin?
Old Jul 26, 2004 | 10:41 AM
vtecjj's Avatar
Default Re: Latest on World Challenge at Sears Point July 2004 (Primo.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Primo. &raquo;</TD></TR><TR><TD CLASS="quote">JM is fast, but can he beat billy auberlin?</TD></TR></TABLE>
JM who?.....Juan Montoya? That would be the only "JM" that would even stand a chance against Auberlen. Billy is just too damn fast.
Old Jul 26, 2004 | 11:10 AM
Footwork's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecjj &raquo;</TD></TR><TR><TD CLASS="quote">JM who?.....Juan Montoya? That would be the only "JM" that would even stand a chance against Auberlen. Billy is just too damn fast.</TD></TR></TABLE>
lol...i meant you mr. meris.
i tip my hat to anyone that can come down here to so cal and rip *** with a 4 door/b16.
you might remember me from lvms back in october 2000.
i ran with tcra red group, then ali and eric asked me to run with you ustcc guys after my race was over, but i was exhausted.
not to mention that the killer bee racing del sol would have had to early apex/crash me when i would have passed him lol.
Old Jul 27, 2004 | 06:18 PM
vtecjj's Avatar
ah yes, the Derek Daley track at LVMS. I remember that weekend, the ustcc race day was cold and windy. I won that race (I really finished sescond) but Richard Holdner/del sol was DQ'd for punting a couple guys off the track, which left me with 1st place. That was when racing was somewhat affordable. Now, for me at least, I'm racing on a shoestring budget...of a shoestring budget.
I appreciate the props too!
Come say "what's up" if you're gonna be at hyperfest at Infineon this Sept. or at the World Challenge race at Laguna Seca.
jmeris
Old Jul 27, 2004 | 09:14 PM
CoryTurner's Avatar
hey so who had that red integra..i was only there for sunday. i was rooting for his car/team..just cause its a teg like mine..but he had to start off in the pits? most likely due to being late to the line? and i like how he passed 3 or 4 people in 2 laps...even the RTR integras and then he just disappeared..my friends and i are wondering what happened.
Old Jul 27, 2004 | 11:48 PM
vtecjj's Avatar
Default Re: (CoryTurner)
If you're talking about the World Challenge race at infineon, then it was Andrew Monterubio's Tech 2 integra (Taz harvey's/DC Sports old Integra). They're really nice people who have been racing in the Series a couple of years now.
You can check out their website at: http://www.tech2motorsports.com/
Old Jul 28, 2004 | 12:02 AM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecjj &raquo;</TD></TR><TR><TD CLASS="quote">If you're talking about the World Challenge race at infineon, then it was Andrew Monterubio's Tech 2 integra (Taz harvey's/DC Sports old Integra). They're really nice people who have been racing in the Series a couple of years now.
lol, funny stuff: http://www.tech2motorsports.co...94115
"The cage is made of Chomemolly steal and is Tig welded to perfection. "
Machine1
Jul 26, 2005 07:23 AM
uglyasscivic
Dec 6, 2002 06:24 AM
hattenDriftR
Nov 11, 2002 05:23 PM
