?about ls vtec ecu
Old Jul 16, 2004 | 10:02 AM
grimald's Avatar
Default ?about ls vtec ecu
I have 92 integra ls block, B16a1 head, B18 type-r high comp pistins, b16 distributer, b16 water pump, b18c-type-r high volume oil pump, and a b16 turbo kit. can i upgrade my ecu for the turbo and use a msd rpm switch? or is there somthing better and easyer?
Old Jul 16, 2004 | 01:31 PM
smart monkey's Avatar
Default Re: ?about ls vtec ecu (grimald)
I would go hondata if going forced induction or look at that uberdata stuff.
Old Jul 16, 2004 | 01:44 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grimald &raquo;</TD></TR><TR><TD CLASS="quote">I have 92 integra ls block, B16a1 head, B18 type-r high comp pistins, b16 distributer, b16 water pump, b18c-type-r high volume oil pump, and a b16 turbo kit. can i upgrade my ecu for the turbo and use a msd rpm switch? or is there somthing better and easyer?</TD></TR></TABLE>
you have, in your car, a high compression lsvtec with a turbo kit?
Old Jul 16, 2004 | 02:08 PM
Default Re: ?about ls vtec ecu (Kamin)
I did a B16a with gsr pistons which is not as high as yours but still high. higher comp motors can take boost but make the tuning window slim. less room for error. probably the best route is to drop the comp ratio
175Shot4Door
Mar 2, 2009 11:06 PM
Lordofdark176
Aug 14, 2007 12:56 PM
nekoabandoned
20
Jun 12, 2006 11:38 AM
sticks51412
Oct 6, 2005 08:57 AM
b16vtecsol
Nov 14, 2003 05:34 PM
