If you have 16's on your ITR
Old Nov 23, 2001 | 04:50 PM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
Default If you have 16's on your ITR
Please let me know
-brand
-width
-offset
-weight
-doe it rub at all? Or small rub on full lock turn? (i guess include the brand/size of the tire you use as well)
JDM 98 R is 16x7 but what offset?
Old Nov 23, 2001 | 04:57 PM
Big Phat R's Avatar
Default Re: If you have 16's on your ITR (frank@b16a.com)
Mugen MF-10 16x7"
50 mm offset
11 lbs
Pirelli P7000Z 225/40 ZR-16
car dropped 1.5" no rubbing
Old Nov 23, 2001 | 05:01 PM
sackdz's Avatar
My street wheels:
Axis Touring Cups
7"
Dunno offset sorry
Too damn much (20 lbs)
No rubbage
[Modified by sackdz, 8:21 AM 11/27/2001]
Old Nov 23, 2001 | 05:58 PM
Mike M's Avatar
Founding Member
Its a 45mm Offset and tire size is 215/45/16
Old Nov 23, 2001 | 06:33 PM
Banned
Default Re: If you have 16's on your ITR (Big Phat R)
thanks for the info. http://g-speed.com/pbh/wheels.html
if the rest of you have any info you would like to supply please post.
i did a quick search on the archive and didn't find too much. i don't think i've seen any listing for wheel info, if it already exists please let me know. looking for ITR specific's.
Old Nov 23, 2001 | 06:54 PM
Benjamin Tang's Avatar
regamaster evo
16x7
+43? (sorry... someone correct me here if i'm wrong because i'm too tired to go out and look)
i'm told around 11-12lbs
advan tnr045 215/45/zr16
car is lowered. camber is corrected, so it does rub under full compression (ie. curbs)
Please let me know
-brand
-width
-offset
-weight
Old Nov 23, 2001 | 06:55 PM
mr2's Avatar
mr2
Default Re: If you have 16's on your ITR (Benjamin Tang)
hey frank whats the deal with your car now.. ?
Old Nov 23, 2001 | 06:56 PM
fangtl's Avatar
16x7 TE37, 43mm offset, with tires 33 lbs (215/45 Azenis), it does rub
Old Nov 23, 2001 | 07:12 PM
woodog's Avatar
16x7 TE37, 43mm offset with 205/45/16's.
It does not rub at stock height.
After I dipped my car, where the top of the tire slightly sits inside the fender, it rubs at full lock.
Old Nov 23, 2001 | 08:09 PM
Rondo's Avatar
Default Re: If you have 16's on your ITR (George Knighton)
16x7 TE37
43mm offset
Dunlop SP9000's (205/45's)
NO RUBBING!
Old Nov 23, 2001 | 08:12 PM
MiraiZ's Avatar
Default Re: If you have 16's on your ITR (Rondo)
stock 16"
215/45 16
Potenza RE-711
45mm offset
Old Nov 23, 2001 | 08:27 PM
fangtl's Avatar
Where does it rub, if you don't mind?
Driver's side, inside of the wheel well. Both front and rear, severity depends on the conditions of the road, and the harshness of the turn...
[Modified by fangtl, 12:32 AM 11/24/2001]
Old Nov 23, 2001 | 10:04 PM
97 TYPE-R 312's Avatar
JDM 16" (White)
16x7"
45
15-17lbs?
It will rub in the front at full lock 215-45ZR16 Azenis
Stock ride height (52K miles - stock shocks/springs)
Thanks,
Victor Perri II
Old Nov 23, 2001 | 11:35 PM
yoshi234's Avatar
I shoot brides
you guys w/ the JDM ITR wheels, you sure your wheels are 45mm offset? Mine had 50 cast into the back of the wheel, just like the USDM wheels.
-y
Old Nov 23, 2001 | 11:38 PM
Austin's Avatar
Default Re: If you have 16's on your ITR (yoshi234)
Mugen MF-10's
+43mm offset
12 lbs...I think
215-45/16 Falken Azenis
stock suspension
slight rub on inside with full lock, just nips the plastic fenderwell liner on the inside.
Old Nov 24, 2001 | 02:09 AM
Jason's Avatar
Default Re: If you have 16's on your ITR (Austin)
Spoon 16 x 7
+45 offset
215-45-16 Falken Azenis, no rubbing
1" drop
Old Nov 24, 2001 | 03:16 AM
Banned
nobody has 7.5" width or even 8" width? i think the "outter" most offset we can use on EG/DC for 7" width is 35 mm offset. that should bring it really flush to the fender. depending on the tire it may or may not rub the fender edge, but that would clear the in side for sure. i guess 7.5" or 8" width will most likely rub on the inside a little but during full lock, which isn't a big deal.
nobody here is into group-a spec setups ehh? 16x8 front 15's on back...
Old Nov 24, 2001 | 04:39 AM
austrian type-R's Avatar
I´ve now 17x8.5 with offset 30, but my fenders a pulled. I´ll change to 16x8 Volk TE37 becuase my 17inchers are heavy
more pics are in my link to webshots
PS: 7.5 with offset 35 should be possible with minor fender work, 8 with offset 40 also possible with minor fender work
[Modified by austrian ITR, 5:41 AM 11/24/2001]
Old Nov 24, 2001 | 06:26 AM
yoshi234's Avatar
I shoot brides
By the way...anybody else blued your Azenis at the track?
The edges do turn a very slight blue, but no where near like the v700s.
My Azenis did rub (barely) at full lock on JDM wheels b/c they were 50mm offset.
yoshi - who can't wait to get on Willow Springs next week!!
Old Nov 24, 2001 | 08:21 AM
zoku's Avatar
A 215 Azeni is wider than a street driven 215 like the RE010 because it is a sort of auto cross type tire. I think I got that from another post. So maybe that might make it more like running a 225? And to run that tire you have to have at least the 50mm offset, right?
Old Nov 24, 2001 | 11:39 AM
fangtl's Avatar
George, you saw my tires at Summit, I blued (more purple than blue if you ask me ) my Azenis pretty badly...
[Modified by fangtl, 3:39 PM 11/24/2001]
Old Nov 24, 2001 | 11:45 AM
Malice's Avatar
New User
hey Frank, any luck finding your hatch?
Old Nov 24, 2001 | 12:54 PM
ic108's Avatar
New User
SSR Schumachers 16x7 215/40/16 yokohama A520's. 35 offset. dumped on its nuts w/ koni's and neuspeed race springs. does NOT rub and the tire is tucked all the way around
Old Nov 24, 2001 | 01:04 PM
ic108's Avatar
New User
Default Re: If you have 16's on your ITR (ic108)
and i have a camber kit all the way around adjusted to -1 degree. absolutely no rubbing what so ever. even with 4 deep
Old Nov 24, 2001 | 01:15 PM
Flux's Avatar
Do you have a photo?
