Tips on hard wiring a V1 radar detector
Old Jul 16, 2004 | 07:00 AM
preludicrous's Avatar
Default Tips on hard wiring a V1 radar detector
I want to hard wire my V1 up near the rearview mirror. Is there a good "hot on start" source up near the map lights or do I need to run it down the pillar to under the dash?
TIA
Old Jul 16, 2004 | 07:51 AM
RemerLex11's Avatar
Default Re: Tips on hard wiring a V1 radar detector (preludicrous)
What kind of radar detector is it.............. and does it work well because mine never do.
Old Jul 16, 2004 | 08:04 AM
Paul H22A4's Avatar
Default Re: Tips on hard wiring a V1 radar detector (mafoo_2005)
v1 = Valentine 1
Old Jul 16, 2004 | 07:21 PM
hAtChXcElR8tion's Avatar
Default Re: Tips on hard wiring a V1 radar detector (Paul97)
i would just go to wallmart..get another cig lighter..get that one tap it into your exisinting light and just route the wires under the dash. Simple..and easy
Old Jul 17, 2004 | 12:22 PM
grifter413's Avatar
I have a V1 as well, nice choice by the way. I hard wired it using the crimp connecting to my battery back-up wire or constant of my head unit. Works great! Then I just ran the wire along the bottom of the dash board, up the door trim, over the the wind-shield and right out to where my V1 is, right above my rear-view mirror.
Old Jul 17, 2004 | 12:48 PM
Default Re: Tips on hard wiring a V1 radar detector (grifter413)
If you were going to hook it up to a constant power source like the one going to your head unit, why didn't you just tap into your map lights? Then there's no need to run the wire down. I was looking for a power source up there that's only live when the car is on. That would eliminate the need to turn on/off the radar. (http://www.bmw330ci.com/DIY_V1.htm) O well, I'll just run it down the side into the dash.
Thanks, everyone for your advice.
Old Jul 17, 2004 | 12:57 PM
Utilitarian's Avatar
That's so funny I stumbled across this. I just got my V1 two days ago and will be hardwiring this weekend (probably into clock).
Old Aug 14, 2004 | 04:54 AM
integra-modder's Avatar
Default Re: Tips on hard wiring a V1 radar detector (Utilitarian)
Back from the dead......but....
When you bought your V1 it should of come with their Direct-Wire Power Adapter. If you bought it used, you can buy it from the guys for 13 bucks. This has a + and - wires and a place to plug it the RJ11 cable that joes between the V1 and its power supply.
Since I drive where radars are illegal, I did this:
Old Aug 14, 2004 | 03:39 PM
skrewdriver88's Avatar
Default Re: Tips on hard wiring a V1 radar detector (integra-modder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-modder &raquo;</TD></TR><TR><TD CLASS="quote">Back from the dead......but....
NICE
Old Aug 14, 2004 | 07:12 PM
ghetto fabulous. How do you mute it when it's way back there?
Old Aug 15, 2004 | 10:55 AM
Default Re: Tips on hard wiring a V1 radar detector (skrewdriver88)
You need to buy 2 aditional things from valentine for this install:
Concealed Display
http://https://store.valentine...0.gif
Remote Audio Adapter
The Concealed Display shows you the direction, band, and strength of the alert.
The Remote Audio Adapter allows you to turn the unit on, off, adjust volume and ofcourse emits the sounds that the valentine usually does on its own.
These two things combined create a very concealed, undetectable, and unnoticible radar install.
BTW, I know that Integra's dont have an ignition switched power wire up near the map lights. I tried looking for one when trying another V1 setup and a lights setup, you just have to run a wire down the pillar and secure it with some good take, no biggie, the panels come off very easy.
Old Aug 16, 2004 | 02:26 AM
Ape's Avatar
Ape
Sorry to highjack but
Grrr..
Im having problems with my V1. It tuns on, all lights and sounds work when its turned on. But im not picking up anything.. I even went to safeway and pointed it at the doors and no sounds or lights. (it use to go off when i drove by) Anyone ever heard of this happening before?
Old Aug 16, 2004 | 04:52 AM
Default Re: Tips on hard wiring a V1 radar detector (Ape)
The only thing i can suggest is the obvious, send it to valentine. I know I wouldnt drive without one.
Old Aug 16, 2004 | 07:44 AM
Boosted_92's Avatar
I love that setup integra modder.
Old Aug 16, 2004 | 05:44 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludicrous &raquo;</TD></TR><TR><TD CLASS="quote">I want to hard wire my V1 up near the rearview mirror. Is there a good "hot on start" source up near the map lights or do I need to run it down the pillar to under the dash?
TIA</TD></TR></TABLE>All Hondas/Acuras have 12v+ conn., acc., 2nd ign., and parklight term. on the incar fusebox, run wires to fusebox, ground close by and plug + into fusebox you will need a female flat spade connecter, don't forget to fuse it. 94
Old Aug 17, 2004 | 05:11 AM
B18EG6's Avatar
Default Re: Tips on hard wiring a V1 radar detector (fcm)
yeh.
like this. Red - 12V ignition
White - 12V illum.
Old Aug 17, 2004 | 08:17 PM
fcm's Avatar
fcm
Old Fart
Default Re: Tips on hard wiring a V1 radar detector (B18EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 &raquo;</TD></TR><TR><TD CLASS="quote">yeh.
White - 12V illum.
</TD></TR></TABLE> **** I wish I could do that. 94
Old Aug 17, 2004 | 08:32 PM
Ludeboi's Avatar
holy ****! is it possible with a 8500?
Old Aug 18, 2004 | 06:53 PM
fcm's Avatar
fcm
Old Fart
Default Re: (Ludeboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ludeboi &raquo;</TD></TR><TR><TD CLASS="quote">holy ****! is it possible with a 8500?</TD></TR></TABLE>Yes 94
Old Aug 21, 2004 | 09:49 AM
Ludeboi's Avatar
how? passport's diplay unit is only two dots. lol
Old Aug 22, 2004 | 08:46 AM
Default Re: Tips on hard wiring a V1 radar detector (Boosted_92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted_92 &raquo;</TD></TR><TR><TD CLASS="quote">I love that setup integra modder. </TD></TR></TABLE>
Thanks....its not that hard, just a paint in the *** to run the wire under the carpet...
Old Aug 23, 2004 | 08:36 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ludeboi &raquo;</TD></TR><TR><TD CLASS="quote">how? passport's diplay unit is only two dots. lol</TD></TR></TABLE>Nothing is impossible, the impossible takes longer and costs more money. 94
Old Aug 23, 2004 | 12:48 PM
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Nothing is impossible, the impossible takes longer and costs more money. 94</TD></TR></TABLE>
maybe the term he was looking for was extremly inefficient....
why is there a 94 everytime you post?
goldsy
Honda CR-V & Element
Jan 7, 2014 09:26 AM
sleEKcpe
16
Jul 23, 2010 09:23 AM
smsimon
Nov 19, 2007 07:22 AM
rafimos
Audio / Security / Video
Nov 5, 2002 09:01 PM
