FS:Drag Gen3 turbo kit in S. Florida
Old Jul 16, 2004 | 06:37 AM
BeaterKiller's Avatar
Default FS:Drag Gen3 turbo kit in S. Florida For B-series in EF
Like the subject line says. Full drag gen3 turbo kit. Has be used, had trouble with getting motor together. no longer need the kit. It is for a B16/B18 in EF, but can be used in any other car with B-series with some minor modification.
Drag High flow 4 into 1 cast iron turbo exhaust manifold
Turbonetics T4/T3 TO4E High flow turbocharger assembly
Turbonetics Delta gate Mark II Wastegate (7 PSI Spring)
Drag High Flow front mount intercooler w/ polished cast aluminum end tanks
Blitz blow-off valve
Drag mandrel bent high flow chrome plated pipes
Drag mandrel bent high flow exhaust down pipe
Drag wastegate dump tube assembly
Drag Blue silicone hose and hose clamps
Drag High pressure/High volume inline fuel pump
Boost dependent FMU fuel regulator
Intake air filter assembly
Map sensor bypass valves
Stainless steel braided oil feed line w/ fittings
Oil return assembly
$1800. Not parting out. It has been used aproximatly 1k miles. I will put up pics in the next few days.
If it doesnt sell here it will be going on ebay.
Pics available by request.
Jason.
Email: JHO001@fiu.edu
Old Jul 18, 2004 | 06:12 AM
Default Re: FS:Drag Gen3 turbo kit in S. Florida For B-series in EF (BeaterKiller)
bump
Old Jul 20, 2004 | 09:40 AM
onefastegg's Avatar
err.....****, this is exactly what i am looking for.... let me see if i can get a loan.....
Old Jul 22, 2004 | 09:42 PM
Siriuswerks's Avatar
I want it Please email siriuswerks@***.net
Old Jul 30, 2004 | 11:51 PM
B18C B TaNg's Avatar
Default Re: (SiRiUsWeRkS)
Old Aug 7, 2004 | 06:45 AM
TURBOLENCE's Avatar
can you send pics?
Old Aug 22, 2004 | 07:06 PM
gen2integra2001's Avatar
can you send pics to gen2integra2001@yahoo.com
Tinberland21
Northeast (Sales)
17
Apr 7, 2008 08:37 AM
Tinberland21
Apr 6, 2008 06:19 PM
sir00
Feb 26, 2006 03:28 PM
Fink2iCe
Aug 11, 2004 12:36 PM
