87 CRX
Well, personally your picking the wrong year crx to do those kind of swaps. You'll want an 88+ crx to make your life a hella of a lot easier.
If you want to stick with the 1st gen crx a D16A1 from 86-89 integra will bolt right in along with the ECU (86-87) and the supsension/brakes.
http://www.redpepperracing.com is the best 1st gen CRX forum. They can help you out quite a bit there,
Good Luck
Blaze
Good Luck
Blaze
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacerBoy »</TD></TR><TR><TD CLASS="quote">Well, personally your picking the wrong year crx to do those kind of swaps. You'll want an 88+ crx to make your life a hella of a lot easier.
If you want to stick with the 1st gen crx a D16A1 from 86-89 integra will bolt right in along with the ECU (86-87) and the supsension/brakes.</TD></TR></TABLE>
with the Hasport mount kit....this car will rock and roll with an LS VTec....and if he did choose the 88-89 D16A, he wants to use the 88-89 ECU not the 86-87. Not hard to swap a motor into the G1 Rex.
Thanks all you guys. right now im not worried about how long it will take me to do this kind of swap cuz i will just keep building it til its done soo when i get the money and have the time you all think the ls vtec would be worth it??
