car is broke down please help
Old Jul 15, 2004 | 10:07 PM
cademan's Avatar
Default car is broke down please help
ok so my car(89 civic hatch) does not start, and i do not know the source of the problem. i dont know if it is my battery(which im pretty sure it isnt, but not going to cross out the idea), my alternator, or could it be my ignition box? i made an earlier post asking for help about alternators but didnt get much response hopefully i can get more help. please give me any helpful input at all, i need to get this car running again and want to do whatever needs to be done myself.
thanks
cade
Old Jul 15, 2004 | 10:14 PM
T-Mo's Avatar
have you tried changing the main relay??? What is the car doing? Is it turning over and not starting, is it not doing anything>> Go into detail a little. I think that you will get a better response that way.
Old Jul 15, 2004 | 10:28 PM
eda6's Avatar
Default Re: (T-Mo)
A better description= a better answer
Old Jul 15, 2004 | 10:30 PM
4DRmafia's Avatar
does the starter clicks alot ?
Old Jul 16, 2004 | 07:12 AM
hndagirl's Avatar
Default Re: (SkipMic2006)
more information please
Old Jul 16, 2004 | 07:32 AM
cademan's Avatar
Default Re: car is broke down please help (cademan)
ok, the car does not click at all, i turn the key and nothing happens, the dash lights come on and thats it. it started the other day at work, it was running fine, and i parked to go back to work after lunch break and when i clocked out 4 hours later the car did not start. so i asked a guy for a jump, and the car wouldnt even jump off. we had to roll start it in the parking lot. and i havent messed with the car since. this is the extent so far on the situation, if there are anymore little things i can do to further narrow down the possibilities please let me know.
thanks
Old Jul 16, 2004 | 07:37 AM
Zeppelin's Avatar
Well, your battery is definitely dead and needs to be replaced. The question is - was it an old battery or did something cause the battery to fail like a faulty alternator?
Old Jul 16, 2004 | 07:51 AM
hndagirl's Avatar
Default Re: (Zeppelin)
it could be the started or alt..have u checked ur distrubitor?
Old Jul 16, 2004 | 07:58 AM
cademan's Avatar
well the battery is only 2 months old, so i guess i get a free one since it should be under warranty. and i did put a system in my car, but nothin major just one amp, and it was only in there for 2 days and i hadnt really even used it. ok so if my alternator is bad, how do i replace it, what tools do i need to replace it?
Old Jul 16, 2004 | 08:00 AM
hndagirl's Avatar
Default Re: (cademan)
heres a question...ur amp...is there a switch to turn it off...maybe u hooked it up, and instead of turning off with the car, it stays on...
that could have drianed your battery
Old Jul 16, 2004 | 08:09 AM
hahagasdcrx's Avatar
Default Re: (black89crxsi)
it could also be your ignition switch wiring, they are known to go out. Check to see if that is it.
should be part number 7 in this pic.
Old Jul 16, 2004 | 01:31 PM
cademan's Avatar
no the amp turns on and off with the car
blackdude
Oct 25, 2007 06:31 PM
WeekH22
May 9, 2005 01:09 PM
thehondabuddy
Jan 28, 2004 09:58 PM
silver_nteg
Nov 27, 2003 07:00 PM
MysteryWagon
Apr 3, 2003 11:56 AM
