CRX H22 swap?
Ok this will be my very first post, for the last 3 days i have been reading all the threads on the H22/crx swap. I toought it was inpossible but you guys inspired me on doing this. Last week a bought a 1990CRX with a B18A+B16 tranny along with new axels, clutch, shiftter assembly for $900 dollars. when i came across this forum after doing research i made up my mind and decided to do an H22 swap.
Now i dont really know much of places to get a full swap, does anyone know a good place that sells full H22 swaps. no luck on ebay i searched and nothing.
Thanks for the help guys
is there other places where they sell swaps with the shift linkage ECU ec. probably even cheaper than hmmotors.com What kind of different trannys can i hook up to the H22 to go into a CRX i know i can use the prelude tranny, but is there another type of tranny i can use thanks.
BTW big props to 2poin2 on that swap is looking sweet.
Modified by crxh22project at 9:34 PM 7/16/2004
I think 2point2 used a Bseries tranny for some reason having to do with superior gearing, but you have to use a custom plate (he made them), and he did alot of other things and from the sound of it he has one sick *** ride
X100
oh yeah
X100oh yeah
I dont think i can PM yet but how much are you asking for the b16 TRANYY ADAPTER.which will would work better the H22 tranny or the B16 tranny on the H22 motor.? thanks for the reply's guys
how much are you asking for it. by using this adapter i dont have to use custom made axels and i can keep my B16 tranny right, also i read something about the b16 tranny being better than H22 trans. is this true
Goto hmotorsonline for your swap.
Remember you get what u pay for. I wouldn't order a motor from anyone else but them. You may pay a little more from them...but you're also getting a nice warranty, and the assurance that you're getting a good motor, along with good customer service.
Is it really worth going somewhere and spending $100 less and "hoping" your motor comes in good condition and runs right...you prolly won't even get a warranty.
The plates sell for 550, you dont have to get the H series tranny if you sue this plate, you dont have to get custom axles or mess with the shift cables. You use you mounts, linkage and axles. The B series tranny is MUCH better then a H. I shaved off .456 off my QT just with the tranny. It would have done better if I had better slicks.
12.8 in the QT with a H22 CRX with Intake and cam gears
12.8 in the QT with a H22 B series tranny CRX with Intake and cam gears
How did you do it to hook up the flywheel. you had an H series before and you didnt like it, so you when with a B series better? Do you make this plates any warranty come with them if they dont fit right. do you have pictures of the plates and stuff. This would make it alot easier right but I dont know if the B series tranny can hold with the H22 on it. what do you think you mind giving me some info also some people are saying that you scam people is this true?
Yea I used a B series tranny because the B series tranny has a better gear ratio and also if you use the stock H22 tranny you have to hack up your car a lot more since it is so dam big, when you use the B series tranny you dont ad that much more weight to your car. It is 11 pounds more instead of 47. Yea there is a 6 month warranty on the plate. The B series tranny can handle just as much HP as a H series. About the "Guy" saying I scammed him it was a huge shipping mishap, Pm him and he will tell you everything is cool.
what comes with your kits i was reading the post on your plates and you where having problems with the plate being 3/8 thick and stuff did you work out all the bugs yet? by the way my tranny ID no dont start with a "Y1" it says "S1" and a bunch of numbers after it can you help me identify this trans mission
Yea well there was problem with the 3/8 plate, but we have redesigned the plate and made some hole adjustments, there is not problems with the plate as of now. The car has been running on the road for about 2 months now everyday and no problems.
is the S1 a good tranny or should i just get another one. Also do you know where i can get an H22 motor ECU harness only not tranny alone everyone tells me it will be hard to find a JDM Motor only,
is the S1 a good tranny or should i just get another one. Also do you know where i can get an H22 motor, ECU, harness only, no tranny.everyone tells me it will be hard to find a JDM Motor only, and that everyone sells full swaps. By the way im in Yuma Az like 2 1/2 hours away from SD what else comes with your kit besides from the plate? would i really have to cut the block to fit it on right?
Yea the S1 is a good tranny, if you have the money go with the LSD Y1 or the LSD YS1, I had to swap trannys because the car would just spin when you got on it in 1st, 2nd and 3rd. You can get them from someone on here or HMotors. You would have to cut a small part of the block to get everything to fit. I have directions that comes with the plate to make to show you everything you need to do.
The plate comes with the Plate, bolts and (milled stater housing ..extra).
Is the S1 tranny a JDM? why should i go with LSD Y1 instead are these trannys stronger dont mind the question i just got into hondas 1 week and half ago when i got the rex. thanks
You need the LSD so you dont spin every time you get on the car. I didnt like drving the car because you would spin. There would be no way in hell in racing someone off the line with no slicks or LSD with this motor in the car. You need something to help the car hook up,
